إنشاء أيقونة بحث مع سمة
أهلاً!
كنت أحاول إدراج أيقونة بجوار رأس البحث لمحاولة تعلم كيفية إدراج العناصر في Discourse كبداية.
لكن هذا لم ينجح.
<script>
node = document.getElementsByClassName('search-page-heading');
node.insertAdjacentElements('beforebegin', '<svg class="PixlzThemeSearchIcon" aria-hidden="true"><use xlink:href="#search"></use></svg>');
</script>
قد يكون خطأً سخيفًا (كما يعلم بعضكم أنني أزداد غباءً في الليل)، ولكن المساعدة محل تقدير.
شكرًا!
Hello,
If I understand correctly you would like to add search icon here on search page :arrow_down_small:
I think for this you need to override the Discourse template.
Here is how to do it: Overriding Discourse templates but I suggest to read the all documentation.
In this case is looks something like this. First you have to find the search page template. Here are the templates: https://github.com/discourse/discourse/tree/main/app/assets/javascripts/discourse/app/templates
The template we looking for is the full-page-search.hbs and we can clearly see which part we should edit to make this change.
This is the heading part of the template which we will edit…but that is a little bit later…
    <h1 class="search-page-heading">
      {{#if this.hasResults}}
        <div class="result-count" id="search-result-count" aria-live="polite">
          {{html-safe this.resultCountLabel}}
        </div>
      {{else}}
        {{i18n "search.full_page_title"}}
      {{/if}}
    </h1>
Now we know from the doc above, we should start like this:
The template goes to the header section.
<script type="text/x-handlebars" data-template-name="full-page-search">
</script>
Than we have to copy the full template inside:
Looks like this
  <DSection @pageClass="search" @class="search-container">
    <ScrollTracker @name="full-page-search" @tag={{this.searchTerm}} @class="hidden" />
    <div class="search-header" role="search">
          </div>
        {{else}}
        {{/if}}
      </h1>
      <div class="search-bar">
        <SearchTextField @value={{this.searchTerm}} @class="full-page-search search no-blur search-query" @aria-label={{i18n "search.search_term_label"}} @enter={{action "search" (hash collapseFilters=true)}} @hasAutofocus={{this.hasAutofocus}} @aria-controls="search-result-count" />
        <ComboBox @id="search-type" @value={{this.search_type}} @content={{this.searchTypes}} @onChange={{action (mut this.search_type)}} @options={{hash
            castInteger=true
        <DButton @action={{action "search" (hash collapseFilters=true)}} @icon="search" @label="search.search_button" @class="btn-primary search-cta" @ariaLabel="search.search_button" @disabled={{this.searchButtonDisabled}} />
      </div>
      {{#if this.usingDefaultSearchType}}
        {{!-- context is only provided when searching from mobile view --}}
        {{#if this.context}}
          <div class="search-context">
            <label>
              <Input @type="checkbox" name="searchContext" @checked={{this.searchContextEnabled}} /> {{this.searchContextDescription}}
            </label>
          </div>
        {{/if}}
        <div class="search-filters">
          <SearchAdvancedOptions @searchTerm={{readonly this.searchTerm}} @onChangeSearchTerm={{action (mut this.searchTerm)}} @search={{action "search" (hash collapseFilters=true)}} @searchButtonDisabled={{this.searchButtonDisabled}} @expandFilters={{this.expandFilters}} />
        </div>
      {{/if}}
      <div class="search-notice">
        {{#if this.invalidSearch}}
          <div class="fps-invalid">
            {{i18n "search.too_short"}}
          </div>
        {{/if}}
      </div>
    </div>
    <div class="search-advanced">
          <div class={{this.searchInfoClassNames}} role="region" ariaLabel={{i18n "search.sort_or_bulk_actions"}}>
            {{#if this.canBulkSelect}}
              <DButton @icon="list" @class="btn-default bulk-select" @title="topics.bulk.toggle" @action={{action "toggleBulkSelect"}} />
              {{#if this.selected}}
                <DButton @class="btn-default bulk-select-btn" @selected={{this.selected}} @action={{action "showBulkActions"}} @icon="wrench" />
              {{/if}}
            {{/if}}
            {{#if this.bulkSelectEnabled}}
              {{#if this.hasUnselectedResults}}
                <DButton @icon="check-square" @class="btn-default" @action={{action "selectAll"}} @label="search.select_all" />
              {{/if}}
              {{#if this.hasSelection}}
                <DButton @icon="far-square" @class="btn-default" @action={{action "clearAll"}} @label="search.clear_all" />
              {{/if}}
            {{/if}}
            <div class="sort-by inline-form">
              <label>
                {{i18n "search.sort_by"}}
              </label>
              <ComboBox @value={{this.sortOrder}} @content={{this.sortOrders}} @onChange={{action (mut this.sortOrder)}} @id="search-sort-by" @options={{hash
                  castInteger=true
            </div>
          </div>
        {{/if}}
      {{/if}}
      <PluginOutlet @name="full-page-search-below-search-info" @tagName="span" @connectorTagName="div" @args={{hash search=this.searchTerm}} />
      {{#if this.searching}}
        {{loading-spinner size="medium"}}
      {{else}}
        <div class="search-results" role="region">
          <LoadMore @selector=".fps-result" @action={{action "loadMore"}}>
              <SearchResultEntries @posts={{this.model.posts}} @bulkSelectEnabled={{this.bulkSelectEnabled}} @selected={{this.selected}} @highlightQuery={{this.highlightQuery}} @searchLogId={{this.model.grouped_search_result.search_log_id}} />
              <ConditionalLoadingSpinner @condition={{this.loading}}>
                {{#unless this.hasResults}}
                  {{#if this.searchActive}}
                    <h3>{{i18n "search.no_results"}}</h3>
                    {{#if this.model.grouped_search_result.error}}
                      <div class="warning">
                        {{this.model.grouped_search_result.error}}
                      </div>
                    {{/if}}
                    {{#if this.showSuggestion}}
                      <div class="no-results-suggestion">
                        {{i18n "search.cant_find"}}
                        {{#if this.canCreateTopic}}
                          <a href {{action "createTopic" this.searchTerm}}>{{i18n "search.start_new_topic"}}</a>
                          {{#unless this.siteSettings.login_required}}
                            {{i18n "search.or_search_google"}}
                          {{/unless}}
                        {{else}}
                          {{i18n "search.search_google"}}
                        {{/if}}
                      </div>
                      <GoogleSearch @searchTerm={{this.searchTerm}} />
                    {{/if}}
                  {{/if}}
                {{/unless}}
                  <h3 class="search-footer">
                    {{#if this.model.grouped_search_result.more_full_page_results}}
                      {{#if this.isLastPage}}
                        {{i18n "search.more_results"}}
                      {{/if}}
                    {{else}}
                      {{i18n "search.no_more_results"}}
                    {{/if}}
                  </h3>
                {{/if}}
              </ConditionalLoadingSpinner>
            {{else}}
                  {{#if this.model.categories.length}}
                    <h4 class="category-heading">
                      {{i18n "search.categories"}}
                    </h4>
                    <div class="category-items">
                      {{#each this.model.categories as |category|}}
                        {{category-link category extraClasses="fps-category-item"}}
                      {{/each}}
                    </div>
                  {{/if}}
                  {{#if this.model.tags.length}}
                    <h4 class="tag-heading">
                      {{i18n "search.tags"}}
                    </h4>
                    <div class="tag-items">
                      {{#each this.model.tags as |tag|}}
                        <div class="fps-tag-item">
                          <a href={{tag.url}}>
                            {{tag.id}}
                          </a>
                        </div>
                      {{/each}}
                    </div>
                  {{/if}}
                  {{#if this.model.users}}
                    <div class="user-items">
                      {{#each this.model.users as |user|}}
                        <UserLink @user={{user}} @class="fps-user-item">
                          {{avatar user imageSize="large"}}
                          <div class="user-titles">
                            {{#if user.name}}
                              <span class="name">
                                {{user.name}}
                              </span>
                            {{/if}}
                            <span class="username">
                              {{user.username}}
                            </span>
                          </div>
                        </UserLink>
                      {{/each}}
                    </div>
                  {{/if}}
                {{else}}
                  {{/if}}
                {{/if}}
            {{/if}}
          </LoadMore>
        </div>
      {{/if}}
    </div>
  </DSection>
</script>
Now we can edit the heading part what I mentioned before. In this case this is a really simple change but you can make more complex changes. Be sure your custom template is always up to date. If there is any change in the core template you should update your custom template as well to works everything fine. :slightly_smiling_face:
In this case we just add an icon {{d-icon "search"}} before full page title and before results count.
The full template looks like this :arrow_down_small:
            {{d-icon "search"}}
          </div>
        {{else}}
          {{d-icon "search"}}
        {{/if}}
      </h1>
            castInteger=true
      </div>
            <label>
            </label>
          </div>
        {{/if}}
        </div>
      {{/if}}
          </div>
        {{/if}}
      </div>
    </div>
              {{/if}}
            {{/if}}
              {{/if}}
              {{/if}}
            {{/if}}
              <label>
              </label>
                  castInteger=true
            </div>
          </div>
        {{/if}}
      {{/if}}
      {{else}}
                      </div>
                    {{/if}}
                          {{/unless}}
                        {{else}}
                        {{/if}}
                      </div>
                    {{/if}}
                  {{/if}}
                {{/unless}}
                      {{/if}}
                    {{else}}
                    {{/if}}
                  </h3>
                {{/if}}
            {{else}}
                    </h4>
                      {{/each}}
                    </div>
                  {{/if}}
                    </h4>
                            {{tag.id}}
                          </a>
                        </div>
                      {{/each}}
                    </div>
                  {{/if}}
                            {{#if user.name}}
                              <span class="name">
                                {{user.name}}
                              </span>
                            {{/if}}
                              {{user.username}}
                            </span>
                          </div>
                        </UserLink>
                      {{/each}}
                    </div>
                  {{/if}}
                {{else}}
                  {{/if}}
                {{/if}}
            {{/if}}
          </LoadMore>
        </div>
      {{/if}}
    </div>
  </DSection>
</script>
Hope this helps :slightly_smiling_face:
حسنًا، لقد نجح ذلك تقريبًا!
لقد قمت بتعديل لافتة البحث، وهي تفعل هذا
لم أكن أعرف أبدًا أنها ستكون بهذا التعقيد، ولكن شكرًا لك! اعتقدت أنها ستكون عبارة عن نص JavaScript بسيط مكون من 3 أسطر
نعم، أعتقد أن هذا بسبب ملف CSS المخصص لديك. ربما تحتاج إلى تخصيص هذه المنطقة. :slightly_smiling_face:
عذرًا على التأخير في الرد ولكن هذه هي لغة CSS الخاصة بها.
svg.PixlzThemeSearchIcon {
      position: relative;
      display: table-row;
      height: 50px !important;
      width: 50px;
      top: 227px;
      left: 220px;
      fill: #e0e0e0;
هل هناك أي شيء خاطئ بها؟
مرحباً،
لا تحتاج إلى إضافة CSS مخصص إلى SVG إذا كنت تريد ظهوره قبل العنوان لأننا وضعناه داخل علامات <h2>، لذا سيستخدم أنماط <h2>. ولكن يجب عليك تعديل قسم عنوان البحث. إذا كنت على صواب، فهذه لقطة الشاشة التي شاركتها أعلاه من السمة الخاصة بك DarkPixlz’s Modern Theme؟
لقد تحققت من تلك السمة وأعتقد أن المشكلة هي أنك تستخدم هوامش داخلية (paddings) وحجم خط كبير جدًا لمحاذاة العنوان في المنتصف، ولا يوجد مساحة كافية لأيقونة البحث.
.search-container .search-page-heading {
  padding: 2em 3.8em;
  font-size: 5em;
اقتراحي:
أستخدم هوامش خارجية (margins) بدلاً من الهوامش الداخلية (paddings) ولكن لا حاجة لها على الجوانب - لأن .search-header لديها بالفعل 10% هوامش داخلية على الجوانب - للحصول على مساحة كافية للأيقونة واستخدام حجم خط أصغر خاصة على الأجهزة المحمولة. لإصلاح المحاذاة الرأسية، يمكنك إضافة 1em هامش خارجي إلى الأعلى حيث أن .main-outlet لديك لديها 3em هامش داخلي في الأعلى.
ربما يكون من الأفضل رؤية ذلك إذا قمت بتغيير الخلفية.
  margin: 1em 0 2em 0;
  font-size: 5em; // استخدم حجم خط أصغر على الشاشات الأصغر
  text-align: center;
شكرا، لقد نجح الأمر :slight_smile:
