Mandatory user field at next login
Hi community, is there a way to prompt users to fill in a particular field in their profile the next time they login?
not that i know of.
maybe you can request it in Contribute > Feature or head over to Marketplace to get someone to build it
You should be able to use the Custom Wizard plugin for this, using the Time and Required settings.
You can find more information here Pavilion
