Hello,
How can i run media.net and other ad networks javascript codes?
סיכום מבוסס בינה מלאכותית
The discussion revolves around using Media.net and other ad networks with the advertising plugin. ufukayyildiz initially inquired about running Media.net and other ad networks’ JavaScript codes. riking suggested using the plugin’s AdSense settings instead. However, ufukayyildiz replied that the plugin doesn’t support their specific needs, such as implementing ads between topics and working with other ad networks.
torsi offered an alternative solution by using Google Ad Manager, which the plugin supports, but cautioned that it has a steep learning curve. ufukayyildiz acknowledged this difficulty.
ShanniiWrites expressed support for adding Media.net to the ad plugin, citing its accessibility for those without AdSense approval or a developer community for Carbon Ads.
The advertising plugin also supports adsense directly, use those settings instead.
Thanks.
adsense ads implemented with ads plugin are not shown steady. i think there is a problem about this.
Also i want to implement ads between topics but i can not do this with ads plugin.
Also this plugin not suitable for implementation of other ads from other networks as media.net
Is there any idea, please?
You can serve almost any ad network or content through Google Ad Manager, which the plugin does support under the DFP/Ad Manager settings.
However, be aware that Ad Manager has a pretty steep learning curve.
thanks. you are right it is really hard to use.
+1 for media.net. It would be a great addition to the ad plugin, as it is more accessible for those who are not approved for AdSense and who do not have a developer community for Carbon Ads
