Mermaid JS Plugin
Repo: GitHub - unfoldingWord/discourse-mermaid: Adds the Mermaid JS library to discourse
Overview
This plugin adds the Mermaid JS library to Discourse so that posts can make use of its features. It turns this:
[mermaid]
gantt
    title A Gantt Diagram
    dateFormat  YYYY-MM-DD
    section Section
    A task           :a1, 2014-01-01, 30d
    Another task     :after a1  , 20d
    section Another
    Task in sec      :2014-01-12  , 12d
    another task      : 24d
[/mermaid]
into this:
See the Mermaid JS site for documentation and more examples.
Installation
The installation notes are available at GitHub - unfoldingWord/discourse-mermaid: Adds the Mermaid JS library to discourse (in short, just add it to app.yml).
Notes
Thanks to @j.jaffeux, version 0.0.3 of this plugin is much easier to install and the generated charts load reliably and immediately.
30 Me gusta
This is very cool, some ideas for future work:
  1. email support here is going to be ultra weak cause it is likely to require very rich feature from email that you can not deliver
I would recommend adding a reduce_cooked email hook (see https://github.com/discourse/discourse/blob/4ad924bcf5acb6c99868887b2a402b7b5f289771/lib/pretty_text.rb#L381-L388 ) you can use image magick to convert SVG to an image, create an upload, tie to post and then add it there. It is fiddly but would add value.
  1. This hack is interesting, cause you could make this wider and support graphviz https://github.com/mdaines/viz.js/
11 Me gusta
Can’t you vendor this lib so a user can skip this step? I believe GitHub - discourse/discourse-math: Official MathJax support for Discourse does this.
11 Me gusta
I’d love to, especially because I’m suspicious that might make the rendering more reliable. However, I can’t see how this happens, can you point me to something more specific?
Hi @jag3773,
I made a PR to this plugin project. It’s now fully lazy loaded and you don ’t need to add anything in your header. Enjoy!
https://github.com/unfoldingWord-dev/discourse-mermaid/pull/1
13 Me gusta
Thanks @j.jaffeux ! As you saw, I merged in your PR and the results are far superior. The charts now load reliably and nearly instantly. I’ve updated the OP along these lines.
7 Me gusta
Really love this plugin, it is very fun to use when you get instant updates in the editor preview pane :smiley:
Is there an easy way to make the plugin work better with dark themes?
There seems to be some example css in https://github.com/knsv/mermaid/tree/master/src/themes but I’m not sure what parts of it I would need to copy over to the theme CSS to make it the default for charts
Right now it looks like this with the bundled Dark theme, I would like to at least make all text and arrows white :
12
3 Me gusta
I’ll add one more thing to my wishlist, it would be great to have a composer button for Mermaid that could insert some example charts and have a link to the documentation site to make it easier for new users to discover all the functionality of the script.
I started looking for a generic toolbar customizer plugin to insert the snippets I need but it doesn’t look like anyone has made one. It would probably make more sense for each plugin to manage their own toolbar extensions anyway.
1 me gusta
I totally agree, the instant updates in the preview pane are awesome!
I see how it doesn’t look great with the Dark theme :frowning: . Unfortunately, I don’t have the know how or capacity to work on a fix for that. However, I would gladly accept a PR that introduces a solution.
Node styling, as described in https://mermaidjs.github.io/flowchart.html does work. But that may be of limited usefulness in addressing the Dark theme issue.
Mermaid has a few themes in their repo, which I imagine you’d be able to select either with a site setting or something. My wild guess would be that this turns into
mermaid.init({ theme: 'dark' }, $mermaid)
Unfortunately none of the current ones (options are ‘dark’, ‘forest’, and ‘neutral’) really look good with DIscourse’s dark theme (they all have black text labels), so my recommendation here for someone willing to work on this (not me sorry :mermaid:)
Is it possible to support the render of the chart while printing (via ctrl+p) when using this mermaid plugin?
Simplest would be just to use the graphviz plugin instead
4 Me gusta
@sam Thanks for the link
Thanks for the plugin! Very useful for Discourse teams.
1 me gusta
Just updated mermaidJS to v8.10.1 thanks to @rishabhlakhotia on Github.
4 Me gusta
En el diagrama de flujo, parte del texto no se muestra en el formato correcto
Especialmente cuando lo necesitas en `` para formatear:
"El **gato** en el sombrero"
Todo está bien en mermaid.live
Esta es una prueba para esta muestra:
flowchart LR
subgraph "One"
  a("`El **gato**
  en el sombrero`") -- "etiqueta de borde" --> b{{"`El **perro** en el cerdo`"}}
subgraph "`**Dos**`"
  c("`El **gato**
  en el sombrero`") -- "`Etiqueta de borde **en negrita**`" --> d("El perro en el cerdo")
Del documento en Flowcharts Syntax | Mermaid
Tenemos el componente de tema Discourse Mermaid aquí en Meta en lugar del plugin, y puedo ver un resultado similar usando el ejemplo:
flowchart LR
subgraph "One"
  a("`El **gato**
  c("`El **gato**
  en el sombrero`") -- "etiqueta de borde **negrita**" --> d("El perro en el cerdo")
Sin embargo, no sigo el ejemplo enlazado, ya que este no parece mostrar el texto en negrita/cursiva en elflowchart resultante: (aunque no muestra el Markdown en sí)
Haré algunas consultas. :slight_smile:
1 me gusta
Gracias. Cambiaré para usar el componente de tema.
Si quieres tener la mejor muestra, puedes probar la muestra en:
2 Me gusta
