Migrer vers Minio
I configured minio as image upload storage, it works well for new uploads, but I can’t migrate olds into that.
root@9c9267547230:/var/www/discourse# rake uploads:migrate_to_s3
Migrating uploads to S3 for 'default'...
Some uploads were not migrated to the new scheme. Please run these commands in the rails console
SiteSetting.migrate_to_new_scheme = true
Jobs::MigrateUploadScheme.new.execute(nil)
when I execute Jobs::MigrateUploadScheme.new.execute(nil) first time, it takes several hours and returned some exception, but seems finally success.
I execute it second time, it returns an empty array [].
and then I try to rake uploads:migrate_to_s3 again, it still says Some uploads were not migrated to the new scheme.
3 « J'aime »
they’re site icons.
This is a known issue, already reported in the following topic:
It’s been a long time since it was promised to be fixed. However unfortunately it’s not fixed yet.
2 « J'aime »
is there any known work-around solution?
I’m currently having a similar problem with Spaces.
3 « J'aime »
I think It should be possible to manually transfer upload files from local to minio by minio client (mc). Then update links by a rake task. However I didn’t try it cause I cant risk it on my community.
In your case if its only a handful of site icons, maybe just upload them manually and update links in your dashboard.
2 « J'aime »
So this is ultimately CORS related as well, @pfaffman?
1 « J'aime »
The problem that I think he was referring to is that migrate_to_s3 won’t run unless everything has been changed to the new scheme but the default/stock images are in the old scheme. And the process that updates them didn’t touch the stock images. (and if you run an update they get recreated)
1 « J'aime »
Can you update to latest and run the rake task again?
I fixed the rake task to only check for uploads made by users otherwise it wouldn’t run.
2 « J'aime »
Oooh! . by_users! I didn’t know about that one. I’ll try to have a look, though it seems pretty clear they should fix it.
I suspect my task is still running.
That’s because it’s new-ish. Was added in
3 « J'aime »
ooh sorry I have already migrated it manually and can’t do this again.
1 « J'aime »
