Over the years we have seen many, many issues with migration to s3, including implicit migrations when restoring a backup.
EXCEPTION: 8 posts are not remapped to new S3 upload URL. S3 migration failed for db 'default'.
Some of the many examples:
- False positives on "posts are not remapped to new S3 upload URL"
- Restore process cancelled at migrating uploads to S3 step
- Restore to New Host
Today, I encountered another one of these and since it was Friday I decided to dive into it instead of just commenting out the check.
So we have this situation:
- we’re on multisite
- let’s assume
dbnameas the database name for this example - we have S3_CDN_URL set
- we do not have CDN_URL set
This is what happens in /lib/file_store/to_s3_migration.rb
First the prefix is decided
prefix = @migrate_to_multisite ? "uploads/#{@current_db}/original/" : "original/"
Then the files are uploaded to s3 and then the remap is done which is basically this and some variations
from = "/uploads/#{@current_db}/original/"
to = "#{SiteSetting.Upload.s3_base_url}/#{prefix}"
So in multisite this will remap
- from
/uploads/dbname/original/ - to
https://bucket-location-url.com/uploads/dbname/original/
and then finally the check is done
cdn_path = SiteSetting.cdn_path("/uploads/#{@current_db}/original").sub(/https?:/, "")
count = Post.where("cooked LIKE '%#{cdn_path}%'").count
if count > 0
error_message = "#{count} posts are not remapped to new S3 upload URL. #{failure_message}"
raise_or_log(error_message, should_raise)
success = false
Now SiteSetting.cdn_path comes from lib/global_path.rb and looks like this
def cdn_path(p)
GlobalSetting.cdn_url.blank? ? p : "#{GlobalSetting.cdn_url}#{path(p)}"
Sooooooo if we do have an S3 CDN but not a regular CDN then SiteSetting.cdn_path("/uploads/#{@current_db}/original") will be simply /uploads/dbname/original
and, per our remap, the new paths are https://bucket-location-url.com/uploads/dbname/original/
That means
cdn_pathis a substring of the new destination path- the
Post.where("cooked LIKE '%#{cdn_path}%'").countwill thus always find posts - it will cry wolf and bail out
