Migration from vBulletin 4.2.3
In the Marketplace category, user kourou seeks assistance to migrate a vBulletin 4.2.3 community to Discourse. The project involves a substantial dataset of 1.66 million posts and 14,000 members, with a MySQL database that requires conversion to UTF-8 encoding. While the client is hosted on Amazon EC2, the hosting provider for the new Discourse instance remains undecided. Due to the need for a proof-of-concept test before committing fully, kourou offers a budget of $100–$150 USD, noting that future work is likely as they lack familiarity with Ruby on Rails and Docker.
User pfaffman responds with interest but cautions that the proposed budget is likely insufficient for the scale of the task. They estimate that importing 1.6 million posts could take a full day, significantly more than the 6–8 hours required for a 230k post import they previously handled. pfaffman highlights that converting the non-UTF-8 database could introduce unpredictable complexity, potentially requiring extensive data scrubbing. They advise that the priority should be a proof-of-concept import to validate feasibility before a full migration. Furthermore, pfaffman notes that if Discourse is not already running, the contractor must also handle the initial setup, as a simple backup file would be inadequate. They conclude that a proper import is realistically a 5–20 hour job, making the current budget unrealistic for the full scope, though the prospect of future engagement adds value to the opportunity.
Hello.
What would you like done?
We use vBulletin 4.2.3 for our community, but we are thinking of switching to Discourse.
Currently our forum has 1.660.000 posts and 14.000 members.
Moreover, our forum’s database (mysql) is not in utf-8 encoding, so we or the person taking over the task should take care of converting it first (or during the migration) to utf-8.
Our main application/website (and forum) is hosted in Amazon EC2 instances, but we have not decided yet wether we are going to install Discourse there too or in a different provider (eg Digitalocean).
When do you need it done?
As soon as possible.
What is your budget, in $ USD that you can offer for this task?
Since we have not yet decided if Discourse meets our needs and we have to test it out thoroughly with real data, we can go up to $100-150.
Of course, since I am not familiar with Ruby On Rails and Docker, the person taking over the task will probably be needed soon for other tasks too.
I’m interested and sent a PM. Here are a few notes about this kind of job for others who are interested in making such a move.
It will probably take a full day to run a 1.6e6 post import. A recent 230K post job I ran took 6-8 hours. If something goes wrong 8 hours in that requires you to start from scratch, it can take a long time. Your budget is probably reasonable for 160K messages, but probably not for 1.6 million.
If converting the data to UTF-8 is as simple as calling scrub, that’s one thing. If it’s anything more than that, you’re looking at potentially a significant amount of time fussing with translations. It’s impossible to tell until you start the job, though.
What you need is a proof-of-concept import so you can see if and whether it’s worthwhile to consider the move in the first place.
If you don’t have Discourse running somewhere already, then you need whoever does this job to set up Discourse for you, as the backup file that one would supply you with isn’t really going to help much, so you’re asking for this to be done as well.
The possibility of future work makes the job more attractive, with the understanding that doing the import right will probably be a 5-20 hour job, not a 1 to 1.5 hour job.
