Yes, that matches what I’m seeing too:
I don’t appear to have a “TEST LIVE URL” button on mine though? ![]()
A few screen shots if it helps:
@davidb things are looking better this morning too:
Is there scope to address the yellow
items too?
I’ve just re-started validation on the ones that are clearly trending downwards and the flat-lining ones:
But this one won’t even pass the pre-validation:
If it helps, there only seem to be two affected topics.
Not sure if relevant but the first post of this topic only contains hyperlinks: https://greyarro.ws/t/new-gimp-3-0-a-viable-free-alternative-to-photoshop/93092
And this one only has a video in the first post: https://greyarro.ws/t/how-to-film-edit-cinematic-fpv-drone-fly-through-dji-03-air-unit/74515
Is a lack of actual content the issue there perhaps?
Thanks, I will investigate this. I suspect it’s because the OP contains no text at all.
We use the OP text as part of the question in the QAPage schema (for topics enabled for Discourse Solved). If there is no text in the OP then we may need to either skip it or use some placeholder (maybe using the topic title in the text value would work) to prevent Google from showing this error.
We already skip individual posts now if they have no text, but it looks like we can have “questions” in this way without body text so will need to account for that.
I saw a new issue crop up yesterday
Missing field “text” (in “mainEntity”)
These appear to be affecting pages with translations. Here’s an example
https://discussion.mcebuddy2x.com/t/mcebuddy-2-3-and-nas/1763/2?tl=zh_TW
Google search is highlighting this:
</span>
</div>
<div class="post" itemprop="text">
<p>这可能是2.3版本的bug,自那以来已有超过500项新功能和修复。请更新到最新版本,如果仍有问题请反馈。</p>
<p>同时看看这个</p>
<aside class="quote" data-post="1" data-topic="25">
<div class="title">
<div class="quote-controls"></div>
<img alt="" width="24" height="24" src="https://discussion.mcebuddy2x.com/letter_avatar_proxy/v4/letter/m/34f0e0/48.png" class="avatar">
<div class="quote-title__text-content">
<a href="https://discussion.mcebuddy2x.com/t/mcebuddy-solution-to-common-errors-and-issues/25?tl=zh_TW">MCEBuddy FAQ - Common Issues and Errors</a> <a class="badge-category__wrapper " href="/c/installation/documentation/7?tl=zh_TW"><span data-category-id="7" style="--category-badge-color: #3AB54A; --category-badge-text-color: #FFFFFF; --parent-category-badge-color: #12A89D;" data-parent-category-id="5" data-drop-close="true" class="badge-category --style-square --has-parent" title="Documentation about Installing and Uninstalling MCEBuddy including User Guides, Tips n Tricks and Solutions to Common Issues"><span class="badge-category__name">Guides and Solutions</span></span></a>
</div>
</div>
<blockquote>
<img width="20" height="20" src="/images/emoji/apple/play_button.png?v=15" title="play_button" alt="play_button" class="emoji"> Table Of Contents:
</blockquote>
</aside>
</div>
<meta itemprop="upvoteCount" content="0"><meta itemprop="url" content="https://discussion.mcebuddy2x.com/t/mcebuddy-2-3-and-nas/1763/2">
</div>
</div>
It’s mainly there but is still be failing on three URLs.
Both failures are for the same three URLs too:
In case it helps, we had two issues: “Missing field ‘name’ (in ‘mainEntity’)” and “Missing field ‘answerCount’ (in ‘mainEntity’)”. After upgrading to v2026.5.0-latest (commit 601e66da60), and triggering a validation from Google Search Console, both the issues are 100% fixed ![]()
I’m also running 2026.5.0-latest (601e66da60) and still face the issue discussed.
Sadly, you cannot trust what Google Search Console is showing you. It has the very annoying habit of adding new cases from its cached index into existing issues, while the validation is running (for up to 30 days). And newly added outdated index entries cause the running validation to fail immediately.
So it is common that one needs to trigger the validation multiple times, up to several dozens of times, or wait for some months, depending on the number of affected pages last crawled before the fix went live. You can verify that the entries which did cause the failure are fine when manually checking their live instance (and comparing the timestamps of the last crawl), and the fact that you can retrigger the validation without issues (otherwise the failed entry would fail the quick preliminary check that is done).
The issue is fully solved on Discourse side. It only takes some months of patience until each page in the Google index was truly updated.
This has been my experience too, even after an issue is fixed it can take months to fully clear it on a large site and only after triggering the same validation multiple times and waiting.
I checked this again today and we are finally down to zero instances of any failures on meta so I think we are probably safe to close this topic now.
This topic was automatically closed after 2 days. New replies are no longer allowed.
