Faltan restricciones NOT NULL y de unicidad en la BD
Hi,
Wanted to make a report about a few validations/constraints that exist in models but are missing in DB.
Missing not null requirements
PostDetail - key, value are required to be present in model but are nullable in DB.
  1. Required in model (app/models/post_detail.rb):
    validates_presence_of   :key, :value
    …But nullable in DB
    discourse_development=# \d post_details
                                            Table "public.post_details"
       Column   |            Type             | Collation | Nullable |                 Default
     key        | character varying           |           |          |
     value      | character varying           |           |          |
    If we add a NOT NULL constraint to the DB, then it’s still possible an empty string gets through, but I think having not null will at least be a little safer
Missing unique constraints
  1. TagGroup - name. Unique in model (app/models/tag_group.rb)
    validates_uniqueness_of :name, case_sensitive: false
    But unique index missing from DB
    discourse_development=# \d tag_groups
    Indexes:
        "tag_groups_pkey" PRIMARY KEY, btree (id)
  2. Likewise, WatchedWord - word. (app/models/watched_word.rb)
    validates :word,   presence: true, uniqueness: true, length: { maximum: 50 }
    DB has a unique index on (action, word) but not on (word) alone:
    discourse_development=# \d watched_words
    Indexes:
        "watched_words_pkey" PRIMARY KEY, btree (id)
        "index_watched_words_on_action_and_word" UNIQUE, btree (action, word)
  3. Finally, WebHookEventType - name. (app/models/web_hook_event_type.rb):
    validates :name, presence: true, uniqueness: true
    Missing unique constraint in DB:
    discourse_development=# \d web_hook_event_types
    Indexes:
        "web_hook_event_types_pkey" PRIMARY KEY, btree (id)
Perhaps someone might be able to confirm if these seem reasonable. It’s possible they will help prevent a bug before it happens. Also, if so, the fix seems like it would be pretty straightforward, and I’m happy to create a pull request if that will be helpful.
Thanks.
Case insensitive unique constraints are a bit tricky, I am uneasy adding the citext extension for this and we would be forced then to go name_lower and dupe the column just to add the index.
Yeah we should fix this
Also fine to add an index here.
