Missing query plans in Data Explorer
While using the data explorer, I recently wondered what ‘Include query plan’ was for. So I enabled it to find out - but I didn’t notice any change.
So I asked someone I’ve learned a lot from over the years and he shared a screenshot of how it’s supposed to look. I was curious why it wasn’t working, so I checked and noticed that explain: true is included in the request send[1], but not included in the response[2]. So I tried to understand where it got lost. At some point I asked ChatGPT because I wasn’t sure where to look next. It was very helpful and navigated me though the whole debugging. I tried the fix, after adding explain: opts[:explain] the query plan appeared. Though I have to admit that I only have a faint idea of what I was doing. That’s why I asked ChatGPT to write a summary of our findings for the bug report[3]:
Bug Summary – Missing `explain` in Query Results (Discourse Data Explorer) AI
Issue:
The explain field was not being included in the JSON response of the Data Explorer /run endpoint, even when explain=true was passed in the request. As a result, query plans were not visible in the frontend UI, even though Postgres returned them correctly.
Root Cause:
While the backend correctly passed opts[:explain] = true into the query execution logic and the result[:explain] value was present, this value was not forwarded to the ResultFormatConverter. The to_json method in ResultFormatConverter only includes the explain key if opts[:explain] == true. However, this option was not included in the convert call.
Fix:
Add explain: opts[:explain] to the call to ResultFormatConverter.convert, like so:
render json:
         ResultFormatConverter.convert(
           :json,
           result,
           query_params: query_params,
           download: params[:download],
+          explain: opts[:explain]
Result:
Once passed correctly, the explain field is included in the JSON response and rendered properly in the frontend UI.
  1. ↩︎
  2. ↩︎
  3. I added the GitHub link and formatted the code snippet ↩︎
Nice job figuring out the issue!
I think it’s a regression from FEATURE: Allows CSV file result to be attached in automated PMs (#318) · discourse/discourse-data-explorer@cbae98f · GitHub.
The code has been refactored, but the explain param is omitted.
Thank you for reporting this issue. It was fixed in this PR:
