I am not sure I am applying CSS correctly. The UI leaves different options…
I got the desktop version styled as desired: https://la.confederac.io/
However, the mobile version is not taking the styles and, in fact, is not offering a menu at all.
Is this the intended behavior currently, or am I missing something?
PS: Also note how mobile site title in two lines leads to overlap with dropdown menu.
Actually, now I see that the burger icon is at the right indeed, but white, which means practically invisible. I’m unable to find the CSS selector to style that fa-bars. Can you help, please?
You can use the below code to change the fa-bars color
.b-header .panel > ul.icons [class^="fa fa-"] {
color: #333;
Thank you very much! fa-bars is now visible.
system
(system)
gesloten
19 juni 2024 om 09:48
5
