移动站点检测不应依赖用户代理中的 Safari
Hi all,
Thanks for the fantastic piece of software that Discourse is, it’s incredible!
We are using Discourse for the community of our app Agenda, our users love it. This is in part because we built it straight in the app using a WKWebView on mac and iOS. Unfortunately this gives a problem on iPhones as apparently discourse fails to detect it’s running on mobile.
Compare the following screenshots taken from Mobile Safari (left) and Agenda (right) on the same device:
The issue seems to be caused by Discourse parsing the User Agent string (left mobile safari, right Agenda using a stock WKWebView) for the word Safari or the word Mobile:
If I indeed tell the WKWebView to set the custom user agent to the same string as mobile Safari it works correctly. Unfortunately this is not a really great solution as it would force us to spoof an incorrect user agent of an incorrect safari version etc. I hope this can be fixed (for example by also checking for the word iPhone)…
Thanks and keep up the great work!
Alex
1 个赞
Unlikely, we have run into many complex issues with string based user agent detection in the past. If you want to 100% be seen as a mobile browser you need the word “mobile” in there from our perspective.
2 个赞
真糟糕。顺便提一下,如果有人遇到同样的问题,这是我添加的变通方法,我想它必须保留:
    // 我们需要强制使用一个被 Discourse 识别为移动端的用户代理
    webView.evaluateJavaScript("navigator.userAgent") { [weak self] result, error in
        if let userAgent = result as? String, error == nil {
            self?.webView.customUserAgent = userAgent + " Mobile"
5 个赞
