モバイルの「トピックコントロール」は、私の太い指には小さすぎる
I have trouble hitting the individual menu items –
They should be taller like the category menu –
The Watching button is also nicely padded.
「いいね!」 12
Sure can you adjust this on mobile @Johani?
「いいね!」 4
I also have trouble with topic controls regularly, I am simply never sure if I hit the right thing.
I wonder if we should consider just using native controls here aka… this built-in thing.
@awesomerobot / @Johani / @j.jaffeux have you thought about this?
There are pros and cons both ways, the native control though is very obvious and goes click.
「いいね!」 4
If we start supporting native iOS drop downs, it’d be great to get Android native support too.
I have that problem too, because my finger pretty much covers the whole menu. I think making them wider would help.
「いいね!」 3
Yeah kind of but no glyphs there unless we use uncode emoji?
Yeah this is a compromise for sure. I am not sure at all this is the correct approach.
One thing that I do notice when I look at native stuff on iOS, is that they like putting more space and lines between items, which helps a lot with fat fingers, eg (mail app does this kind of stuff):
They also tend “dim” the other parts of the UX while you are dealing with one of these things and slide it up from the bottom.
Not married to any particular solution here, but I do have constant issues with “topic controls” on mobile which I use a fair bit due to defer.
「いいね!」 6
今朝は「フラグを立てる」ではなく「アサイン解除」をタップしてしまいました。そのため、モバイル版のコンボボックスのパディングを増やす小さな変更を行いました。
変更前と変更後:
「いいね!」 11
