Modification when you hover over the topic
The discussion revolves around a modification that would change topic behavior when hovered over. Pirat shared an image of the idea, which Pad_Pors finds acceptable only if triggered by a click, citing potential messiness when moving the mouse. erlend_sh expressed skepticism about the feature’s usefulness, suggesting it would need to be a very popular plugin before being considered for core support. TechnoBear echoed Pad_Pors’ sentiments, disapproving of hover-triggered pop-ups due to potential irritation and advocating for a disable option, while finding click-triggered pop-ups acceptable.
Good time of day.
Want to suggest such a thing
「いいね!」 2
I can understand this behavior when I click on a topic and not hover. otherwise it will be too messy as one move the mouse in the page.
meanwhile, the click behavior may be useful as you won’t go out of the topic list and you won’t lose your position.
「いいね!」 1
the idea also normal
この機能を備えたどのフォーラムでも、私はこれが本当に有用であると感じたことはありません。コア機能としてこのサポートを検討し始める前に、まず非常に人気のある#customization:プラグインとして確立されていることを確認する必要があります。
I also showed a screenshot
I think this is very cool idea
Or as one doesn’t move the mouse.
I navigate largely by keyboard, which means I pay little attention to where my mouse cursor is resting. Having that kind of pop-up appear for no apparent reason would be both disconcerting and irritating, IMHO. I would definitely want an option to disable it for myself. On click - OK; but not on hover.
