What would you like done?
We are looking for someone to modify the Discourse Tab Bar component so it shows for logged out users and on all screen sizes and is always visible.
When do you need it done?
ASAP
What is your budget, in $ USD that you can offer for this task?
$100
Are you planning to have all the same tabs regardless of a user being logged in or not?
Would you be interested in taking on this task?
Yes, I’ll send you a message.
Thanks for the work, was completed fast and were notified on every step
