Modifica collegamento in evidenza dell'argomento
I haven’t found any way to modify the featured link for a topic
How can I achieve that?
The only way I can see to modify the featured link is to edit it through the rails console.
You can only delete it, not modify it at this time.
Can you give me a hint for the command?
Find the topic_id that you want to change the featured link for - it’s the first number in the URL in your browser’s address bar. SSH into your server and enter the rails console. Then run:
t = Topic.find(your_topic_id)
t.featured_link = 'http://example.com/new/featured/link'
t.save
C’è un modo per farlo tramite l’API HTTP?
Speravo che Discourse API Docs permettesse di farlo, ma sembra di no
