BryanV requests a feature to insert templates inline—exactly at the cursor position—without forced newlines, which currently disrupts workflow when crafting replies with embedded links like GitHub Issue. He emphasizes the need for text-only, keyboard-driven insertion and criticizes the plugin’s automatic whitespace addition as unnecessarily restrictive, since templates can already include formatting. pfaffman suggests Watched Words/Replace, but notes it doesn’t fully meet the need. BryanV clarifies that context-sensitive replacements are risky and prefers full control. He reiterates the annoyance in post 4, questioning if there’s a better venue for feature requests, but JammyDodger confirms this is the right place, noting community support boosts prioritization. Others suggest alternatives: Heliosurge mentions the Discourse Templates plugin and proposes forking the eBay Affiliates component to add user/group-based keyword replacement or shorthand codes. Qwerty8 confirms BryanV is using the plugin but dislikes its newline behavior, which BryanV again calls a functional downgrade. The core issue remains: templates should insert exactly as authored, without imposed formatting.
I would like the ability to paste replies “inline” i.e. in the middle of a sentence. I had requested this for the previous other plugin, and there was some (seemingly positive) discussion about it, but I have not been able to locate that previous discussion.
I very often need to craft replies that have e.g. GitHub Issue in the middle of a sentence:
If you’d like to request [thing] as a new feature, please open a GitHub Issue
[Feature] is under-documented, a GitHub Issue would be appropriate to increasing visibility.
[Some behavior] seems to be a bug, please open GitHub Issue with full details.
I have lots of these kinds of snippets, and use them constantly in our user support forum.
Generically, I’d like to be able to insert templates right exactly at the current cursor position. [1] It’s really annoying to have the template get inserted on a newline with another newline above it, and have to manually delete all that whitespace just to get it back up to the previous cursor position, several times every day. I just want to type my reply as fast as possible.
Even better would be a text-only way to insert these without having to use any mouse/menu interactions at all.
I woud argue that the entire benefit of using the category posts to store templates is that it can afford full control. Just insert the template at the cursor position exactly, as-is. If whitespace/newlines are desired, they are easily added in the template editor—there’s no need to force decisions on us. ↩︎
Watched Words/Replace might help you out. It’s how things like standard install automatically get linked. When I tried to replace with a markdown link, though, the raw markdown gets inserted into the post, so it’s not quite what yuo want, I’m afraid.
Oh, but if all you want is for Github Issue to get linked, that works already.
I gave “GitHub Issue” link as a simple motivating example, but it is only one of several various. There are also snippets that are full sentences that I might insert in a larger paragraph, e.g. as part of a reply explaining why a different forum is more appropriate.
I also wouldn’t want every instance of “GitHub Issue” to link to our tracker unconditionally and unpreventably. 95% of the time it’s what is desired, but there are certainly times that people need to talk about GitHub Issues on other trackers, and not being able to prevent a replacement in places where it would be wrong is arguably worse.
Ultimately I just don’t understand the need to force a particular behaviour here, when the post editor already provides all the tools for anyone to to whatever they want or need. Adding in arbitrary out-of-band whitespace only serves to reduce the scope of functionality.
As this continues to be a near daily annoyance for me, I have to ask if there is some other, better way or place to request features?
Given that the editor itself affords all the ability needed to include newlines (or not), then just inserting the editor text without any modification at all would afford everyone a way to get what they need. I truly do not understand why the utility of relying on the editor for templates is artificially undermined by arbitrarily and unavoidably introducing things outside the editor texts.
Another option would be to fork and modify the eBay Affiliates theme component to check if poster is in support group or is say you and replace keywords with your appropriate link
One benefit to forking is you could create a support short hand code to auto replace with a link or say a paragraph as you mentioned.
Thanks missed that. The 2nd option posted could work as that component is designed to modify eBay links with an affiliate modded link with disclaimer.
So if retooled to check post author against group or user in theory might be a very sweet way of accomplishing the goal and even improve on the idea via short codes to speed things up.
Here is the place. This is where our product and dev teams collect and review suggestions to decide which to prioritise in any given cycle.
Generally, the more people who desire a feature and contribute to/engage with/support the Contribute > Feature request the higher its chances of being allocated some dev time.
Some feature requests can take awhile to pick up steam depending on how widely they resonate.
That is correct. Adding arbitrary unconditional newlines to a template that is already capable of expressing newlines wherever desired only serves to strictly reduce the available functionality.
