Most effective way of creating large amount of sub-forums
Hi,
We’re looking at implementing discourse into an existing application which has a large userbase broken down into schools at the nationwide level.
In an ideal world, each school with have its own private “sub-forum” of which only users from that school can post, which each sub-forum having approx 3 categories (always the same).
If this setup something thats possible in discourse and if so whats the best way of implementing this assuming there may be thousands of schools/sub-forums?
From an initial look it seems it may be possible to create a group per school and then assign users to the group, but creating thousands of groups via API seems like the wrong approach
Any thoughts appreciated!
Yes, it’s possible (each school could have one category with 3 sub-categories) but you’ll have huge performance issues if you create thousands of categories.
I suspect that you might want to use a multisite install and have each school have its own forum via multisite. The particulars of how you’d manage thousands of multisite forums is likely beyond the kind of help that you can get here.
Are you planning to authenticate against SSO against something?
And you want one group per school? Is this just for teachers and not students?
PostgreSQL 데이터베이스를 직접 업데이트하는 작은 Ruby 스크립트를 작성하면 실제로 쉽게 수행할 수 있습니다.
Ruby를 사용하여 이 “상당히 단순한” DB 쿼리 스크립팅 작업을 수행하기 위해 API를 사용할 필요는 없습니다.
