I believe that the free space can be useful
for example, for advertising, for chat, for important novovstey
This would be under “customizing the topic list template” which is sort of possible.
I do suggest using glyphs rather than words for these fields though. Like the eyeball glyph usually means “views”, etc. Example:
Less to translate, too.
glyphs occupy a lot of space, I do not think that this is a good idea
No, glyphs do not occupy more space than words; I’m proposing replacing the words with glyphs.
yes, good idea
if you are talking about:
symbol of replies, views and activities
I also think you can remove the user in the mobile version
