Move wrench to bottom in mobile layout
As discussed internally, we probably want to move the admin wrench in the mobile layout from top right to the bottom, sticking it to the pagination widget:
10 curtidas
Sure I support that.. can you make it so @eviltrout?
I just upgraded and found that this has been implemented :thumbsup: However, with the button at the bottom, the menu now opens off screen…
2 curtidas
I also noticed it doesn’t get docked when you scroll all the way down (iOS Safari).
3 curtidas
It hasn’t been implemented fully yet. It was an attempt at doing it via CSS and is incomplete. I’m working on a proper fix and should hopefully deploy it this afternoon.
7 curtidas
This should do it:
https://github.com/discourse/discourse/commit/34867a6e07f3874106c14cf2b9c7359b555191de
8 curtidas
Excellent looks great now
5 curtidas
