Moving posts to a long topic fails
I’m aware I’ve probably exceeded the reasonable number of posts to move, and now it fails with the message:
There was an error moving posts.
I was trying to move 19 posts from a 1,500-post topic into a 4,500-post topic.
Still, it would be great if there was a solution.
Moving to a new topic works fine.
Unicorn worker received USR2 signal indicating it is about to timeout, dumping backtrace for main thread
config/unicorn.conf.rb:203:in `backtrace'
config/unicorn.conf.rb:203:in `block (2 levels) in reload'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:110:in `exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:110:in `async_exec'
(eval at /var/www/discourse/lib/method_profiler.rb:38):29:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_sql-1.6.0/lib/mini_sql/postgres/connection.rb:217:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_sql-1.6.0/lib/mini_sql/active_record_postgres/connection.rb:38:in `block in run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_sql-1.6.0/lib/mini_sql/active_record_postgres/connection.rb:34:in `block in with_lock'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_sql-1.6.0/lib/mini_sql/active_record_postgres/connection.rb:34:in `with_lock'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_sql-1.6.0/lib/mini_sql/active_record_postgres/connection.rb:38:in `run'
/var/www/discourse/lib/mini_sql_multisite_connection.rb:109:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_sql-1.6.0/lib/mini_sql/postgres/connection.rb:196:in `exec'
(eval at /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_sql-1.6.0/lib/mini_sql/builder.rb:62):2:in `exec'
/var/www/discourse/app/models/topic_user.rb:511:in `update_post_action_cache'
/var/www/discourse/app/models/post_mover.rb:634:in `update_statistics'
/var/www/discourse/app/models/post_mover.rb:116:in `move_posts_to'
/var/www/discourse/app/models/post_mover.rb:35:in `block in to_topic'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:6...
activesupport-7.2.2.1/lib/active_support/broadcast_logger.rb:130:in `block in warn'
activesupport-7.2.2.1/lib/active_support/broadcast_logger.rb:231:in `block in dispatch'
activesupport-7.2.2.1/lib/active_support/broadcast_logger.rb:231:in `each'
activesupport-7.2.2.1/lib/active_support/broadcast_logger.rb:231:in `dispatch'
activesupport-7.2.2.1/lib/active_support/broadcast_logger.rb:130:in `warn'
/var/www/discourse/lib/signal_trap_logger.rb:40:in `public_send'
/var/www/discourse/lib/signal_trap_logger.rb:40:in `block (2 levels) in ensure_logging_thread_running'
<internal:kernel>:187:in `loop'
/var/www/discourse/lib/signal_trap_logger.rb:37:in `block in ensure_logging_thread_running'
I’m on latest core version b6f62bcc05
Is there still a plan to move the logic to a sidekiq?
There is a recent post about a similar issue:
Maybe try to update if you’re not on the last version.
I’ve noticed..
We could buy you a bit more time and kick this to the defer queue quite easily, that would give 90 seconds vs 30 seconds for the work.
I am a bit concerned that it takes so long here, updating stats does feel like something we should be able to do later after the posts moved.
I’ve done the hijack for now, but yes there is likely a bunch of other optimizations to make here:
https://github.com/discourse/discourse/pull/31029
