Moving the voting box to the right side of the screen
סיכום מבוסס בינה מלאכותית
A user, verilog15, is experiencing an issue with the voting box on their RTL (Hebrew) forum, as it appears on the left side instead of the right. They requested an option to move it to the right side or a possible CSS code solution. According to Johani, the issue will be fixed via a plugin update (https://github.com/discourse/discourse-voting/pull/44).
I use the voting plugin and my forum is in Hebrew so its RTL. But the voting box is on the left side and not on the right side:
Is it possible to add an option to move it to the right side of the screen? maybe some css code to make it to the right side?
Thank you!
4 לייקים
@Johani is there a plugin fix required here?
2 לייקים
This will be fixed via
Thanks for reporting the issue @verilog15 :+1:
4 לייקים
This topic was automatically closed after 25 hours. New replies are no longer allowed.
