מספר openid-connect authentication providers
I am looking for a plugin to support SSO with an OpenID connect provider (specifically Keycloak) but need to be able to support multiple realms, and therefore multiple openid connect providers.
From what I have read on the OpenID connect plugin, you can only setup a single client which uses a discovery document such as https://{keycloak_server_url}/auth/realms/{realm}/.well-known/openid-configuration
However we have users across many realms in keycloak that need to be supported by a single (self hosted) Discourse installation.
Is there any way to allow Discourse to be setup with mutiple clients and then use a short url to initiate a SSO with a specific realm e.g.
https://{discourse_server}/sso/realm/A
https://{discourse_server}/sso/realm/B
https://{discourse_server}/sso/realm/C
Each with their own OAUTH client config.
Hey there, I’m exactly looking into the same issue. I’m wondering if you found a solution since then by any chance?
Thanks :slight_smile:
@MSG160 , @ImaCrea
Did either of you found a solution? :grin:
