Multiple posts delete unstable?
A user, Steven, has reported an issue with deleting multiple posts in Discourse. The problem seems to be related to the number of posts selected, with the following behaviors observed:
  • Selecting 10 or fewer posts usually works fine.
  • Selecting 10-30 posts may show a brief “deleted” background (red), but the posts are actually deleted after a refresh.
  • Selecting 30+ posts can result in posts remaining undeleted, but may be deleted after a refresh and some time (possibly due to Sidekiq processing).
Codinghorror suggests that there is a UI issue with deletion not always reflecting the outcome, and that selecting hundreds of posts may trigger a server timeout. Zogstrip mentions that deleting posts can take a significant amount of time (up to several seconds per post) and has made some improvements to the user experience in a recent commit.
Sorry for my english, it’s a bit technical for me.
When I use the wrench then the following options : Select Posts... > delete selected after selecting 5+ posts, it’s buggy, sometimes
The first time I tried this : I selected 200+ posts, deleted it, but when I refreshed the page, they weren’t deleted.
After upgrading to the latest version, I didn’t try to delete 100+ posts again, I try a few at a time
  • If I select 10 or less posts, it usually works fine
  • if I select between 10 and 30 posts the selected posts have the deleted background (red in my case) for a few seconds then change to their usual background (white background)… But after a refresh they are in fact deleted.
  • If I select 30+ posts, the posts can stay undeleted. (EDIT : in fact, after a refresh one minute later, they are deleted. It makes sense, must be sidekiq who needs time)
It’s not an exact science, sometimes it works fine, sometimes not, it’s a bit weird.
Tested on Firefox and Chrome on latest Discourse version.
1 „Gefällt mir“
There is a UI issue here with deletion, where it doesn’t always reflect what happens.
If you are selecting hundreds :exploding_head: of posts then that’s probably a server timeout instead.
1 „Gefällt mir“
Deleting posts take a lot of time (up to several seconds per post). I did improve the user experience in
https://github.com/discourse/discourse/commit/1b4483c9425f9d8dae7a7b298752303bc0165f37
3 „Gefällt mir“
This topic was automatically closed after 3 days. New replies are no longer allowed.
