Problemi con Dockerfile multisite
Ho provato ad applicarlo leggendo le guide. Ecco come è finito il file app.yml. Potrebbero esserci degli errori. Sto usando solo Docker. Il mio obiettivo è: poter aprire 2 siti su un server virtuale. 1. nome sito: dursuncan.com, 2. nome sito: forum.tekno-byte.com
Come dovrei modificare il file app.yml?
   # ./launcher rebuild app
    WARNING: We are about to start downloading the Discourse base image
    This process may take anywhere between a few minutes to an hour, depending on your network speed
    Please be patient
    2.0.20210415-1332: Pulling from discourse/base
    Digest: sha256:b3b1eb6d859d683f26ad2a02e0efabcd502a63ab07b8211e4c425aa7ba7dd3a4
    Status: Downloaded newer image for discourse/base:2.0.20210415-1332
    docker.io/discourse/base:2.0.20210415-1332
    Fetching origin
    Launcher is up-to-date
    Stopping old container
    + /usr/bin/docker stop -t 60 app
    app
    cd /pups && git pull && git checkout v1.0.3 && /pups/bin/pups --stdin
    docker: Error response from daemon: could not get container for postgres: No such container: postgres.
    See 'docker run --help'.
    cat: cids/app_bootstrap.cid: No such file or directory
    "docker rm" requires at least 1 argument.
    See 'docker rm --help'.
    Usage:  docker rm [OPTIONS] CONTAINER [CONTAINER...]
    Remove one or more containers
    rm: cannot remove 'cids/app_bootstrap.cid': No such file or directory
    ## this is the all-in-one, standalone Discourse Docker container template
    ## After making changes to this file, you MUST rebuild
    ## BE *VERY* CAREFUL WHEN EDITING!
    ## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
    ## visit http://www.yamllint.com/ to validate this file as needed
    templates:
      - "templates/cron.template.yml"
      - "templates/sshd.template.yml"
      - "templates/web.ssl.template.yml"
      - "templates/web.letsencrypt.ssl.template.yml"
    ## which TCP/IP ports should this container expose?
    ## If you want Discourse to share a port with another webserver like Apache or nginx,
    ## see https://meta.discourse.org/t/17247 for details
    expose:
    #  - "80"
       - "80:80"
       - "2222:22"
       - "443:443"
    #  - "80:80"   # http
    #  - "443:443" # https
    links:
       - link:
           alias: postgres
    #docker_args:
    #   - "--net chain"
    params:
      #db_shared_buffers: "256MB"
      #db_work_mem: "40MB"
      #version: tests-passed
    env:
      LC_ALL: en_US.UTF-8
      LANG: en_US.UTF-8
      LANGUAGE: en_US.UTF-8
      #UNICORN_WORKERS: 3
      ## Required. Discourse will not work with a bare IP number.
      DISCOURSE_HOSTNAME: 'dursuncan.com'
      # VIRTUAL_HOST: 'dursuncan.com,www.dursuncan.com'
      # LETSENCRYPT_HOST: 'dursuncan.com,www.dursuncan.com'
      # LETSENCRYPT_EMAIL: 'merhaba@dursuncan.com'
      ## Uncomment if you want the container to be started with the same
      ## hostname (-h option) as specified above (default "$hostname-$config")
      # DOCKER_USE_HOSTNAME: true
      DISCOURSE_DEVELOPER_EMAILS: 'poyrazdursuncan@gmail.com'
      ## TODO: The SMTP mail server used to validate new accounts and send notifications
      # SMTP ADDRESS, username, and password are required
      # WARNING the char '#' in SMTP password can cause problems!
      DISCOURSE_SMTP_ADDRESS: smtp.eu.mailgun.org
      DISCOURSE_SMTP_PORT: 587
      DISCOURSE_SMTP_USER_NAME: postmaster@mg.dursuncan.com
      DISCOURSE_SMTP_PASSWORD: '***'
      DISCOURSE_SMTP_ENABLE_START_TLS: true
      DISCOURSE_SMTP_DOMAIN: dursuncan.com
      #DISCOURSE_NOTIFICATION_EMAIL: noreply@discourse.example.com    # (address to send notifications from)
      ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
      LETSENCRYPT_ACCOUNT_EMAIL: 'merhaba@dursuncan.com'
      ## The http or https CDN address for this Discourse instance (configured to pull)
      ## see https://meta.discourse.org/t/14857 for details
      ## The maxmind geolocation IP address key for IP address lookup
      ## see https://meta.discourse.org/t/-/137387/23 for details
      #DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
      DISCOURSE_DB_HOST: some-host
      DISCOURSE_DB_NAME: "{{config}}_discourse"
    labels:
      monitor: "true"
      app_name: "{{config}}_discourse"
    volumes:
      - volume:
          guest: /shared
      - volume:
          guest: /var/log
    ## Plugins go here
    hooks:
      after_postgres:
         - exec: sudo -u postgres createdb b_discourse || exit 0
         - exec:
              stdin: |
                grant all privileges on database b_discourse to discourse;
              cmd: sudo -u postgres psql b_discourse
              raise_on_fail: false
         - exec: /bin/bash -c 'sudo -u postgres psql b_discourse <<< "alter schema public owner to discourse;"'
         - exec: /bin/bash -c 'sudo -u postgres psql b_discourse <<< "create extension if not exists hstore;"'
         - exec: /bin/bash -c 'sudo -u postgres psql b_discourse <<< "create extension if not exists pg_trgm;"'
      after_code:
        - exec:
            cd: $home/plugins
            cmd:
              - mkdir -p plugins
      before_bundle_exec:
        - file:
            path: $home/config/multisite.yml
            contents: |
             secondsite:
               adapter: postgresql
               database: b_discourse
               pool: 25
               timeout: 5000
               db_id: 2
               host_names:
                 - b.discourse.example.com
      after_bundle_exec:
        - exec: cd /var/discourse && sudo -E -u discourse bundle exec rake multisite:migrate
    run:
      - exec:
            cd: var/discourse
            hook: my_hook
            cmd:
              - echo 1
Sono necessari due contenitori di questo tipo e un reverse proxy davanti. Copia app.yml in app2.yml e modificalo. Esecuzione di altri siti web sulla stessa macchina di Discourse o forse Configurazione multisito con Let’s Encrypt e senza reverse proxy se possono condividere gli stessi plugin e lo stesso server di posta.
Ho utilizzato il primo metodo sui server LEMP. È possibile implementare questo metodo tramite Docker? L’installazione di un server nginx al di fuori di Docker influisce sulle prestazioni?
Sì. Avrai un’immagine Docker per ogni forum.
Anche il reverse proxy esterno può essere un contenitore Docker.
Molto poco.
Ho installato Nginx. Ho configurato le impostazioni. Ho modificato il file app.yml. Il processo di rebuild fallisce. Qual potrebbe essere il problema?
Assicurazione che launcher sia aggiornato
Recupero origin
Launcher è aggiornato
docker: formato di riferimento non valido: il nome del repository deve essere in minuscolo.
Vedi 'docker run --help'.
cat: cids/app_bootstrap.cid: File o directory non trovati
"docker rm" richiede almeno 1 argomento.
Vedi 'docker rm --help'.
Uso:  docker rm [OPZIONI] CONTENITORE [CONTENITORE...]
Rimuove uno o più container
rm: impossibile rimuovere 'cids/app_bootstrap.cid': File o directory non trovati
** FALLIMENTO NEL BOOTSTRAP ** scorri verso l'alto e cerca i messaggi di errore precedenti, potrebbero essercene più di uno.
./discourse-doctor può aiutare a diagnosticare il problema.
root@dursun:/var/discourse# docker image rm 8e23824acd3c
Errore: Immagine non trovata: 8e23824acd3c
app.yml
## questo è il template del container Docker Discourse all-in-one, standalone
## Dopo aver apportato modifiche a questo file, DEVI eseguire rebuild
## FAI MOLTA ATTENIONE DURANTE LA MODIFICA!
## I FILE YAML SONO MOLTO MOLTO SENSIBILI A ERRORI NEGLI SPAZI O NELL'ALLINEAMENTO!
## visita http://www.yamllint.com/ per validare questo file se necessario
## template di base utilizzati; è possibile ridurli per includere meno funzionalità per container template:
  #- "templates/sshd.template.yml"
  #- "templates/web.socketed.template.yml"
## quali porte TCP/IP deve esporre questo container?
## Se desideri che Discourse condivida una porta con un altro server web come Apache o nginx,
## vedi https://meta.discourse.org/t/17247 per i dettagli
## quali porte esporre?
## expose: commenta l'intera sezione inserendo un # davanti a ogni riga
# - "80:80"   # http
params:
  ## Imposta db_shared_buffers a un massimo del 25% della memoria totale.
  ## verrà impostato automaticamente dal bootstrap in base alla RAM rilevata, oppure puoi sovrascrivere
  ## può migliorare le prestazioni di ordinamento, ma aumenta l'utilizzo di memoria per connessione
  ## Quale revisione Git dovrebbe utilizzare questo container? (predefinito: tests-passed)
env:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  ## Quante richieste web concorrenti sono supportate? Dipende dalla memoria e dai core della CPU.
  ## verrà impostato automaticamente dal bootstrap in base alle CPU rilevate, oppure puoi sovrascrivere
  #UNICORN_WORKERS: 3
  ## TODO: Il nome di dominio a cui risponderà questa istanza di Discourse
  ## Obbligatorio. Discourse non funzionerà con un semplice indirizzo IP.
  ## Scommenta se desideri che il container venga avviato con lo stesso
  ## hostname (opzione -h) specificato sopra (predefinito "$hostname-$config")
  ## TODO: Elenco di email separate da virgola che diventeranno amministratori e sviluppatori
  ## all'iscrizione iniziale, ad esempio 'user1@example.com,user2@example.com'
  ## TODO: Il server SMTP utilizzato per validare nuovi account e inviare notifiche
  ## INDIRIZZO SMTP, nome utente e password sono obbligatori
  ## ATTENZIONE: il carattere '#' nella password SMTP può causare problemi!
  DISCOURSE_SMTP_PASSWORD: '---------'
  #DISCOURSE_NOTIFICATION_EMAIL: noreply@discourse.example.com    # (indirizzo da cui inviare le notifiche)
  ## Se hai aggiunto il template Lets Encrypt, scommenta qui sotto per ottenere un certificato SSL gratuito
  ## L'indirizzo CDN http o https per questa istanza di Discourse (configurato per il recupero)
  ## vedi https://meta.discourse.org/t/14857 per i dettagli
  ## La chiave IP Maxmind per la geolocalizzazione per la ricerca degli indirizzi IP
  ## vedi https://meta.discourse.org/t/-/137387/23 per i dettagli
## Il container Docker è stateless; tutti i dati sono archiviati in /shared
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## I plugin vanno qui
## vedi https://meta.discourse.org/t/19157 per i dettagli
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
## Qualsiasi comando personalizzato da eseguire dopo la costruzione
run:
  - exec: echo "Inizio dei comandi personalizzati"
  ## Se desideri impostare l'indirizzo email 'From' per la tua prima registrazione, scommenta e modifica:
  ## Dopo aver ricevuto la prima email di iscrizione, riscommenta la riga. Deve essere eseguita solo una volta.
  - exec: echo "Fine dei comandi personalizzati"
