Multisite installation with seperated smtp emails
The discussion revolves around configuring separate SMTP email settings for different sites in a multisite Discourse installation. suanfazu and 5minpause initially struggled to achieve this, and sam confirmed that multisite installations currently don’t support multiple outgoing SMTP servers.
However, sam expressed willingness to consider a pull request for this feature, suggesting that email settings should be in site settings with the option to be shadowed by globals.
SimonBiggs explored the possibility of funding the implementation of this feature, but later discovered that the desired effect could be achieved by not setting the DISCOURSE_NOTIFICATION_EMAIL environment variable, allowing site-specific email settings to be configured.
silverdr proposed the details of the changes that could be implemented, including the possibility to override all SMTP configuration variables per site or, at a minimum, override the SMTP user name and password per site.
I followed this post to setup doctor multisites.
but how to configure different smtp email settings for different sites?
I tried this as well and couldn’t get the second site to use different settings from the first site.
Perhaps @sam could offer an opinion, if this is a known bug or something else.
We don’t support multiple outgoing SMTP servers in multisite
Thanks for the answer. Is this something you would consider given a pull request? Does it make sense to invest time in?
Sure, if you can pull it off, its pretty complicated, but I would be open to have a PR for it and would kind of prefer if email settings were in site settings as long as they can be shadowed by globals.
@sam様
この機能を実装した場合、資金提供の可能性はありますでしょうか?現在、政府からMVP助成金(https://www.nsw.gov.au/grants-and-funding/mvp-ventures-program)の獲得を検討しており、皆様からのご支援があれば、政府からのマッチングで1ドル対1ドルで調達することができ、大変ありがたいです:slight_smile:。
よろしくお願いいたします。
Simon
提案されているすべての変更について、詳細を教えていただけますか?
こんにちは @sam さん、
実は、以下の環境変数を設定しない場合:
app.yml 内で、設定項目に以下の設定が表示されることに気づきました:
そして、これを使用してまさに望んでいた効果を得ることができます。
この可能性に対してオープンでいてくださった @sam さん、ありがとうございます :slight_smile:。今回は PR は不要になりそうです。
最大/ベスト:
  • マルチサイト構成でサイトごとにすべてのSMTP構成変数をオーバーライドする機能
  • DISCOURSE_SMTP_ADDRESS
  • DISCOURSE_SMTP_PORT
  • DISCOURSE_SMTP_USER_NAME
  • DISCOURSE_SMTP_PASSWORD
  • DISCOURSE_SMTP_ENABLE_START_TLS
  • DISCOURSE_SMTP_DOMAIN
最小:
  • サイトごとに以下のSMTP関連変数をオーバーライドする機能
config/multisite.yml の同等の設定で
最小の背景:他に選択肢がない場合、1つのSMTPサーバーで対応できるように設定できますが、個別のSMTPユーザー(送信者)が必要になります。Discourseサイトが実行されているドメインとは異なるドメインからのメール送信アドレスは、残念ながら取引を成立させるには不十分なようです。
