xan2622
(xan2622)
September 23, 2022, 3:13pm
1
Following the same idea than this one: adding a X button to leave the channel …
I think that it would make sense to give users the ability to mute channels (to stop seeing the dot next to the channel name) … to stop being notified of new replies in the channel.
khenmu
(John Sweeney)
September 23, 2022, 4:32pm
This is already possible, albeit less convenient to do.
Here’s how to go about it;
Toggle on the sidebar, if it is not already visible.
Tap on the icon in the ‘Channels’ header.
Hover-over the header to force the icon to appear if you don’t see it.
Tap on the icon in the card of the channel you want to mute.
Switch to the Settings tab if it doesn’t default to that (I would expect it to).
There will be an option to mute the channel.
edit: Here’s some direct links for convenience;
edit 2: I do like the suggestion in the OP, FWIW.
mcwumbly
(Dave McClure)
September 24, 2022, 1:41am
3
I think we need a right-click context menu or something if we want to have easier access to various channel controls like this.
