My site displays a blank page after update - plugin compatibility issue
hello, my site (https://ipoffice.ovh)displays a blank page after the last upgrade. in safe-mode I can access it. do you have the same concern ?
2.5.0.beta4
(279835f603)
Then you should remove or disable the plugin that is causing the problem.
thank you it was indeed the extension Babble.
