Blank page after upgrade due to broken plugin
AI 生成的摘要
After upgrading Discourse using ./launcher rebuild app, users accessing discourse.skcript.com without logging in encountered a blank page. The issue arose after switching from the test-passed to stable channel, triggering a database migration error Karthik_K. codinghorror advised against downgrading and recommended disabling all third-party plugins before rebuilding. dax specifically pointed to the guest gate plugin as the culprit, noting it’s broken and causes blank pages. Karthik_K confirmed that disabling the plugin resolved the issue. pfaffman provided additional context with links to relevant Meta Discourse threads discussing the plugin’s known issues and alternatives.
I run my community at discourse.skcript.com. Yesterday, I upgraded the platform using ./launcher rebuild app. After the upgraded completed, users who try to access the platform without logging in are getting a blank page.
The app.yml is set to test-passed by default. When I change it to the stable channel, this is the error I get:
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 11533 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
78b52f8ae680a31781647884748760b39c844756e8097fa3e7c3a4b0c8002c90
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
Can someone please help me with this?
You can’t downgrade from tests-passed to stable; it doesn’t work because your DB has changed.
Disable all third party plugins and rebuild.
Thanks for the info Jeff. Let me try that right away.
If you are using the guest gate plugin then disable it, it’s broken and give you a blank page.
That was exactly the issue. Disabled it and it works now. :slight_smile:
See this: Guest Gate (Sign Up Popup Plugin) - #21 by vinothkannans Or, better, Content Lockers - using pop-ups
