האתר שלי תמיד מושבת
סיכום מבוסס בינה מלאכותית
The user danielabc is experiencing a persistent website downtime due to a server error (500) caused by running out of disk space (100% used). The issue is linked to the Docker daemon not running, which prevents the Discourse app from starting. The community suggests troubleshooting steps such as cleaning logs with journalctl --vacuum-time=1s, removing old backups from /var/discourse/shared/standalone/backups/default, and deleting orphaned Docker images using docker images and rm. However, the consensus is that the root cause is insufficient storage, and the long-term solution is to upgrade the server size or migrate to a larger droplet. Benjamin_D and merefield emphasize that manual cleanup is a temporary fix, and the server has outgrown its current capacity, especially with multiple full backups and uploads consuming space. JammyDodger provides guidance on identifying and removing large files, while Jagster stresses that resizing the server is the most reliable solution. The user also expresses confusion about Discourse’s automatic cleanup, which is not fully automatic in this setup. Ultimately, the community advises against further attempts to free space manually and recommends upgrading the server to prevent recurring issues.
server error
when trying to load /latest.json?ascending=false
Error code: 500 error
This page is not working www.dexforum.com.br is currently unable to fulfill this request.
HTTP 500 ERROR
Why is this happening? How to solve?
Your error message says No space left on device and the system info shows 100.0% of 49.29GB used.
You’ll have to increase your droplet size or see what is currently on it that’s using all the space.
I thought that the site content was automatically deleted from the server, how do I see what is causing all this size?
There’s some good info on how to look after your server in Manually update Discourse and Docker image to latest
Thanks for showing me this step by step but when I use the command cd /var/discourse git pull ./launcher rebuild app it shows Device "docker0" does not exist. Cannot connect to the docker daemon - verify it is running and you have access
It sounds like your app is stopped. Try ./launcher start app, and that should bring back your pre-rebuild version.
cd /var/discourse
Don’t run ./launcher cleanup unless your app is running, otherwise it will remove that as well.
another error happened, omg, I didn’t even know about those
root@forummaisvc:/var/discourse# ./launcher start app
Device “docker0” does not exist.
I used the command df -h What can I delete? And what command do I use to delete a specific thing?
Try:
cd /var/discourse
./launcher restart app
it’s returns this to me =(
Jim is still right…
I’d try sudo apt autoremove --purge then sudo systemctl start docker and .\launcher start app and then maybe .\launcher cleanup (with some backup made beforehand)
I tried these codes you gave me and it gives me some errors! I don’t know what else to do, my forum is down for days, I’m desperate
I always get a bit nervous about suggesting deleting things to create space. Is there a beginner-friendly step-by-step for targeting maybe the extra back-up files, or some orphaned images?
not even enough space to apt autoremove :fearful:
Oh yes, all proportion kept I feel a bit like
maybe sudo apt autoclean first
and for a fistfust of Ko sudo find /var/log -type f -iname *.gz -delete
then try again sudo apt autoremove
and finally sudo systemctl start docker
sudo /var/discourse/./launcher start app
sudo /var/discourse/./launcher cleanup
what is dock Daemon? how install it? @Benjamin_D @JammyDodger
I’m afraid you currently don’t have enough space to start docker, which you would need to then run ./launcher cleanup (which would be the preferred way to tidy up any old containers/images leftover from previous rebuilds). Ideally, you’d also want your site to be live (./launcher start app) before you run it, so you have a fallback if anything goes awry with the rebuild.
I haven’t had a site that’s 100% full, so it’s a little unclear to me what may or may not work (autoclean and autoremove not being able to run, for instance). @Benjamin_D Do you know if it’s still possible to manually remove some files to free up a bit of space to get the ball rolling? eg.
cd /var/discourse/shared/standalone/backups/default dir
Copy the oldest file name, and then paste to remove it eg:
rm jammydodger-s-test-site-2022-04-12-033748-v20220407195246.tar.gz
Or possibly check for orphaned images and remove one or more of those:
docker images
Though it’s probably also worth mentioning that if your site has a lot of user uploads it may be that you simply need to resize. But if you haven’t done any server maintainence since you started, there’s a good chance a tidy up should tide you over for a while.
I think I’d aim at logs before anything more “app related”
sudo journalctl --rotate
sudo journalctl --vacuum-time=1s
I don’t know anything, but I would do first the most obvious thing: checking out if docker is on at all — as it says all the time:
systemctl status docker
I found this topic with a similar issue:
@JammyDodger @Benjamin_D
Thanks for helping me and answering me!
I thought Discourse deleted files automatically!
How do I see which files are crowding my storage? And which files can I delete?
Do I do this using command or can I go to the forum settin
