Name of a new group
Hi all,
I’m trying to create a new group. In the first section I should enter a name:
Should it be in English? Because it does not give me to enter non-english letters.
Also, what is the difference between those three sections?
And one last question. How can I undo displaying the group name beside the user’s name?
  • name = the name of your group. must only include numbers, letters, dashes, and underscores
  • group name = the full name of the group.
  • default title = gives the title you enter to every member of the group.
I assume that you mean the title?
Either remove the default title or go to user admin page and remove it from there.
It should work in Hebrew; can you confirm it is failing for a single Hebrew word? Do you have Unicode usernames enabled? Cc @gerhard
Thank you for the explanation. I can’t find it in the admin page. Can you tell me what is the name of the settings?
Allowing Unicode characters solved the problem :slight_smile:
Maybe separating this option into two suboptions (usernames and group names) could be a nice feature :smiley:
