Hi,
i have a inp issue on mobile in my forum from some time now. Google shows 547 ms right now.
I"m debugging it from 1 month, and it’s looks like the main issue is the search in mobile. Debugbear shows me that:
BUTTON#search-button.onclick, [.search-dropdown button#search-button] - 392ms INP
Is there a easy fix for this?
thank you
pmusaraj
(Penar Musaraj)
October 10, 2025, 12:34pm
3
Can you post more details from the inspector/debugging? Also, which theme are you using, is it a custom one or one of the themes provided by Discourse core?
In the past, i was using the FKB Pro - Social theme , but now, i’m using the default theme for two months without no changes in the inp metric.
Also, i dont use any plugins, except the Google One Tap Login/Signup
Here’s the screenshot i have from debugbear and cloudflare rum:
I am currently testing now without the summary functionality, from the Discourse AI
