محتاج للمساعدة بخصوص تحديث discourse
Hello there,
I was doing a discourse update yesterday and when I ran sudo ./launcher rebuild app, but then it hanged and took longer than expected, and I then the session stopped, and when I ran it again it started causing errors, and now I can roll back to the previous version nor can the update complete, its bring this error attached.
Error Log
FAILED
Pups::ExecError: if [ -f /root/install_postgres ]; then
/root/install_postgres && rm -f /root/install_postgres
elif [ -e /shared/postgres_run/.s.PGSQL.5432 ]; then
socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
fi
failed with return #<Process::Status: pid 17 exit 1>
exec failed with the params {"tag"=>"db", "cmd"=>"if [ -f /root/install_postgres ]; then\n /root/install_postgres && rm -f /root/install_postgres\nelif [ - e /shared/postgres_run/.s.PGSQL.5432 ]; then\n socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running s top container ; exit 1\nfi\n"}
916e1f975678294573c1aea2e7df8e72a915ca151d151cead82853d63ea577c7
**Launcher Logs**
WARNING: Docker version 20.10.7 deprecated, recommend upgrade to 24.0.7 or newer.
x86_64 arch detected.
WARNING: containers/app.yml file is world-readable. You can secure this file by running: chmod o-rwx containers/app.yml
run-parts: executing /etc/runit/1.d/00-ensure-links
run-parts: executing /etc/runit/1.d/00-fix-var-logs
run-parts: executing /etc/runit/1.d/01-cleanup-web-pids
run-parts: executing /etc/runit/1.d/anacron
run-parts: executing /etc/runit/1.d/cleanup-pids
Cleaning stale PID files
run-parts: executing /etc/runit/1.d/copy-env
Started runsvdir, PID is 40
ok: run: redis: (pid 53) 0s
ok: run: postgres: (pid 54) 0s
supervisor pid: 49 unicorn pid: 84
Shutting Down
run-parts: executing /etc/runit/3.d/01-nginx
ok: down: nginx: 1s, normally up
run-parts: executing /etc/runit/3.d/02-unicorn
(49) exiting
ok: down: unicorn: 0s, normally up
run-parts: executing /etc/runit/3.d/10-redis
ok: down: redis: 1s, normally up
run-parts: executing /etc/runit/3.d/99-postgres
ok: down: postgres: 0s, normally up
ok: down: nginx: 5s, normally up
ok: down: redis: 2s, normally up
ok: down: unicorn: 4s, normally up
ok: down: cron: 1s, normally up
ok: down: rsyslog: 1s, normally up
Started runsvdir, PID is 34
ok: run: redis: (pid 47) 0s
ok: run: postgres: (pid 48) 0s
supervisor pid: 43 unicorn pid: 78
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Stopping Sidekiq
(43) Reloading unicorn (78)
(43) Waiting for new unicorn master pid...
(43) Waiting for new unicorn master pid... 1160
(43) Waiting for new unicorn workers under 1160 to start up...
(43) Old pid is: 78 New pid is: 1160
(43) Reloading unicorn (1160)
(43) Waiting for new unicorn master pid... 2227
(43) Old pid is: 1160 New pid is: 2227
(43) Reloading unicorn (2227)
(43) Waiting for new unicorn master pid... 3212
(43) Old pid is: 2227 New pid is: 3212
(43) Reloading unicorn (3212)
(43) Waiting for new unicorn master pid... 8648
(43) Old pid is: 3212 New pid is: 8648
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reopening logs
(43) Reloading unicorn (8648)
(43) Waiting for new unicorn master pid... 17648
(43) Old pid is: 8648 New pid is: 17648
(43) Reloading unicorn (17648)
(43) Waiting for new unicorn master pid... 19642
(43) Old pid is: 17648 New pid is: 19642
Shutting Down
ok: down: nginx: 0s, normally up
(43) exiting
ok: down: unicorn: 1s, normally up
ok: down: redis: 0s, normally up
ok: down: nginx: 10s, normally up
ok: down: postgres: 1s, normally up
ok: down: redis: 6s, normally up
ok: down: unicorn: 10s, normally up
ok: down: cron: 0s, normally up
ok: down: rsyslog: 0s, normally up
Started runsvdir, PID is 35
ok: run: redis: (pid 51) 0s
ok: run: postgres: (pid 47) 0s
supervisor pid: 44 unicorn pid: 79
Shutting Down
(44) exiting
timeout: run: redis: (pid 51) 263s, want down, got TERM
run-parts: /etc/runit/3.d/10-redis exited with return code 1
ok: down: unicorn: 9s, normally up
kill: run: redis: (pid 51) 272s, want down, got TERM
ok: run: redis: (pid 49) 0s
ok: run: postgres: (pid 46) 0s
Shutting Down
(43) exiting
ok: down: unicorn: 5s, normally up
Started runsvdir, PID is 36
ok: run: redis: (pid 50) 0s
supervisor pid: 49 unicorn pid: 80
Shutting Down
(49) exiting
ok: down: nginx: 11s, normally up
ok: down: redis: 7s, normally up
ok: down: unicorn: 11s, normally up
ok: run: redis: (pid 45) 0s
ok: run: postgres: (pid 53) 0s
supervisor pid: 42 unicorn pid: 73
Shutting Down
(42) exiting
ok: down: nginx: 6s, normally up
Shutting Down
(44) exiting
supervisor pid: 49 unicorn pid: 73
Shutting Down
(49) exiting
supervisor pid: 44 unicorn pid: 73
Shutting Down
(44) exiting
ok: down: redis: 3s, normally up
ok: down: unicorn: 6s, normally up
supervisor pid: 44 unicorn pid: 72
config/unicorn_launcher: line 71: kill: (72) - No such process
config/unicorn_launcher: line 15: kill: (72) - No such process
(44) exiting
ok: run: redis: (pid 49) 17s
ok: run: postgres: (pid 46) 17s
supervisor pid: 104 unicorn pid: 108
config/unicorn_launcher: line 71: kill: (108) - No such process
config/unicorn_launcher: line 15: kill: (108) - No such process
(104) exiting
ok: run: redis: (pid 49) 21s
ok: run: postgres: (pid 46) 21s
supervisor pid: 122 unicorn pid: 126
config/unicorn_launcher: line 71: kill: (126) - No such process
config/unicorn_launcher: line 15: kill: (126) - No such process
(122) exiting
ok: run: redis: (pid 49) 27s
ok: run: postgres: (pid 46) 27s
supervisor pid: 141 unicorn pid: 145
config/unicorn_launcher: line 71: kill: (145) - No such process
config/unicorn_launcher: line 15: kill: (145) - No such process
(141) exiting
ok: run: redis: (pid 49) 32s
ok: run: postgres: (pid 46) 32s
supervisor pid: 159 unicorn pid: 163
config/unicorn_launcher: line 71: kill: (163) - No such process
config/unicorn_launcher: line 15: kill: (163) - No such process
(159) exiting
ok: run: redis: (pid 49) 37s
ok: run: postgres: (pid 46) 37s
supervisor pid: 177 unicorn pid: 181
config/unicorn_launcher: line 71: kill: (181) - No such process
config/unicorn_launcher: line 15: kill: (181) - No such process
(177) exiting
ok: run: redis: (pid 49) 41s
ok: run: postgres: (pid 46) 41s
supervisor pid: 195 unicorn pid: 199
config/unicorn_launcher: line 71: kill: (199) - No such process
config/unicorn_launcher: line 15: kill: (199) - No such process
(195) exiting
ok: run: redis: (pid 49) 46s
ok: run: postgres: (pid 46) 46s
supervisor pid: 213 unicorn pid: 217
config/unicorn_launcher: line 71: kill: (217) - No such process
config/unicorn_launcher: line 15: kill: (217) - No such process
(213) exiting
ok: run: redis: (pid 49) 51s
ok: run: postgres: (pid 46) 51s
supervisor pid: 231 unicorn pid: 235
config/unicorn_launcher: line 71: kill: (235) - No such process
config/unicorn_launcher: line 15: kill: (235) - No such process
(231) exiting
ok: run: redis: (pid 49) 56s
ok: run: postgres: (pid 46) 56s
supervisor pid: 250 unicorn pid: 254
config/unicorn_launcher: line 71: kill: (254) - No such process
config/unicorn_launcher: line 15: kill: (254) - No such process
(250) exiting
ok: run: redis: (pid 49) 61s
ok: run: postgres: (pid 46) 61s
supervisor pid: 268 unicorn pid: 272
config/unicorn_launcher: line 71: kill: (272) - No such process
config/unicorn_launcher: line 15: kill: (272) - No such process
(268) exiting
ok: run: redis: (pid 49) 66s
ok: run: postgres: (pid 276) 2s
supervisor pid: 298 unicorn pid: 302
(298) Reopening logs
Shutting Down
(298) exiting
Your quick response will be highly appreciated.
لا يمكنك التراجع.
تأكد من تكوين مساحة المبادلة (عادةً 4 جيجابايت على الأقل). ليس من الصعب أن تنفد الذاكرة من العملية.
أعد البناء مرة أخرى بمجرد تأكيد مساحة المبادلة وشارك السجلات إذا فشلت مرة أخرى.
لا يزال يعرض نفس رسائل الخطأ حتى بعد إضافة الذاكرة المشتركة إلى 6 جيجابايت
قد يمنحك هذا مزيدًا من المعلومات
قد يكون هذا هو السبب. قم بترقية Docker، وقد تحتاج إلى ترقية نظام التشغيل الخاص بك للقيام بذلك. أوصي بالقيام بذلك عن طريق الانتقال إلى جهاز افتراضي جديد، ولكن هناك طرق أخرى يستخدمها الآخرون.
قد يكون أيضًا مشكلة في الأذونات مع postgres.
