sunjam
(james.network)
April 30, 2022, 3:58pm
1
Helping @rakekniven sort out forum performance issues and users are no longer able to upload images. This error has been cropping up a lot. Seems this person is also having similar errors and is also unable to upload images .
Plugins on the forum
Canned Replies
discourse-checklist
discourse-legal-tools
discourse-solved
docker_manager
styleguide - disabled
Message (661 copies reported) on 2.9.0.beta4
#<Net::OpenTimeout: execution expired>
Backtrace
/usr/local/lib/ruby/2.7.0/net/http.rb:960:in initialize' /usr/local/lib/ruby/2.7.0/net/http.rb:960:in open’
/usr/local/lib/ruby/2.7.0/net/http.rb:960:in block in connect' /usr/local/lib/ruby/2.7.0/timeout.rb:105:in timeout’
/usr/local/lib/ruby/2.7.0/net/http.rb:958:in connect' /usr/local/lib/ruby/2.7.0/net/http.rb:943:in do_start’
/usr/local/lib/ruby/2.7.0/net/http.rb:932:in start' /usr/local/lib/ruby/2.7.0/net/http.rb:606:in start’
/var/www/discourse/lib/final_destination.rb:515:in safe_session' /var/www/discourse/lib/final_destination.rb:455:in safe_get’
sunjam
(james.network)
April 30, 2022, 8:37pm
3
Upload error
Net::OpenTimeout : execution expired
Message (273757 copies reported)
Failed to process hijacked response correctly : Net::OpenTimeout : execution expired
Backtrace
/var/www/discourse/lib/final_destination.rb:147:in get' /var/www/discourse/lib/file_helper.rb:68:in download’
/var/www/discourse/app/controllers/user_avatars_controller.rb:158:in proxy_avatar' /var/www/discourse/app/controllers/user_avatars_controller.rb:51:in block in show_proxy_letter’
/var/www/discourse/lib/hijack.rb:56:in instance_eval' /var/www/discourse/lib/hijack.rb:56:in block in hijack’
/var/www/discourse/lib/scheduler/defer.rb:94:in block in do_work' rails_multisite-4.0.1/lib/rails_multisite/connection_management.rb:80:in with_connection’
/var/www/discourse/lib/scheduler/defer.rb:89:in do_work' /var/www/discourse/lib/scheduler/defer.rb:79:in block (2 levels) in start_thread’
Env
sunjam
(james.network)
May 12, 2022, 4:05pm
4
Found this on stackoverflow for resolving the issue in Ruby:
It seems to be a problem with certain versions of libc which resolve DNS routes. After spending couple hours to search solution you just need to add require 'resolv-replace' at the beginning of your code.
More information: Use Ruby DNS resolver to handle DNS timeout in Net::HTTP by pranas · Pull Request #597 · ruby/ruby · GitHub
Hope this help somebody in the future.
