News Plugin 📰
Follow the steps here and pull from this link GitHub - paviliondev/discourse-news: Adds a news stream to your Discourse instance
「いいね!」 2
Is it possible to add multiple feeds from different sources. It seems like we can add only one XML from only one source.
「いいね!」 2
Hey @Pravi, thanks for using the plugin.
No, it is not currently possible to add multiple feeds.
「いいね!」 1
Any future update on multiple feeds?
「いいね!」 2
Hi,
I’ve got the Pavilion News plugin in my new discourse install - and I’m testing it out with posts and users and have run into a number of issues that I’m wondering if other News plugin users might have found a work around for?
Load times for home page?
Is there any way to control the number of news posts that are initially downloaded when a person, anonymous user comes to the site? It seems that it downloads the entire news section (every single post) at once - which seems crazy. As I’ve added News items to fill up the site a bit, load times for the home page have dramatically increased. When I just had a post or two load times were in the 200 ms range - but now with 10 or 15 posts the load time is up to 1500ms.
Stripped out images from the news posts?
Other than the top most image, any images that are in the post seem to be stripped out of the post so that when people read the /news feed the can’t see any of the images that the text in the body refers to. Very strange…
Embedded Videos - Don’t play, replaced by static image, with link to YouTube - thus side-stepping the embedded video ability. Takes the people off the site - which basically remove a feature from discourse.
Any suggestions appreciated!
「いいね!」 2
Sorry, this isn’t a solution, but those should just lazy load and show a static image before playing.
「いいね!」 2
The basic concept here is that the News Plugin sits at and enhances a Topic List view of either a list of topics or RSS feed.
Thus the “per-Topic” view is simpler than a single Topic view would be expected to be, but richer than the default, image-less “venetian blind” format of a regular Discourse Topic List.
This is expected and a practical compromise.
  • the plugin’s primary focus is RSS feeds and supports one featured image per “post”, however, it can also show an image from a Discourse Topic.
  • If you want to see the other images you can navigate to the full Topic.
  • this is partly to ensure performance is reasonable. To show all images from all Topics would be a large download.
  • This also keeps the layout more compact.
  • Same goes for embedded videos on Topics, these are just presented as a thumbnail on the news feed, just like they would be on all equivalent plugins and theme components that display on the Topic List.
Is this for RSS or Discourse Category based feeds? If the latter there may be some performance enhancement potential by sourcing a low resolution thumbnail instead of the full sized image and applying lazy loading … however given the size of the laid out image a low resolution image might not cut the mustard.
If your interest is not in RSS feeds then you might also want to check out Topic List Previews TC which is a bit more optimised for that task, but has a different flavour of layout.
「いいね!」 1
Hi Rober - thanks for the explanation. This is not for an rss type application - this is for more of a blog + forum application. I wanted to avoid the hassles and overhead of having both a Wordpress site and the discourse forum since its a small side project for me.
How do you apply “lazy loading” - I’m not a coder, and not familiar with that setting.
Thanks for your info.
「いいね!」 2
That’s a feature request.
「いいね!」 1
You can’t. But it is a feature that should be in use nowadays anyway. So, hopefully devs of Discourse come to modern time :wink:
(No, I don’t know how difficult it would be, but nearly every other platforms use it, and for reason)
「いいね!」 2
Actually, it’s a fairly trivial change that doesn’t need to involve the Discourse team, which I’ve gone ahead and made:
IMPROVE: rename raw templates and add lazy loading for thumbnail · paviliondev/discourse-news@6150851 (github.com)
I’ve also deployed a set of fixes for breaking changes and modernised the template suffixes:
COMPATIBILITY: settings references · paviliondev/discourse-news@dcda6a7 (github.com)
@angus
「いいね!」 5
こんにちは、プラグインをインストールしたばかりで、サイトはデフォルトのテーマで実行されています。画像がモバイルとデスクトップの両方で画面外に表示されています。この修正方法はありますか?
「いいね!」 1
「ディスコースのニュースソース」とは何でしょうか? カテゴリであれば、画像は期待どおりに表示されます(こちらを参照)。
RSSフィードの場合、画像のサポートはフィードのバージョンによって異なります。RSS 1.x の場合、RSS 1.x 仕様には公式な画像サポートがないため、プラグインはそれらのフィードの画像をサポートしません。
RSS 2.0 の場合、画像サポートは enclosure タグを通じて提供されます。フィードアイテムには次のような属性が必要です。
<enclosure url="http://feed.com/image.jpg" length="12345" type="image/jpeg" />
さらに詳しくは以下をご覧ください。
「いいね!」 2
こんにちは。はい、このフィードリンクでした。
「いいね!」 1
良いニュースは、フィードがRSS 2.0であり、実際にはエンクロージャータグに画像が含まれていることです。そのため、期待どおりに表示されます。
フィードを例としてtry.thepavilion.io/newsに読み込みました。次のサイト設定が設定されていることを確認してください。
  • discourse news enabled: true
  • discourse news source: RSS
  • discourse news rss: https://cointelegraph.com/rss/tag/altcoin
「いいね!」 1
トピック内の特定の投稿からニュースであることを示すために、投稿にニュースとしてタグ付けすることは可能ですか?
より詳しい説明:私たちのフォーラムでは、メンバーが定期的にニュースを投稿しており、それをニュースとして表示するために、この投稿にニュースタグを適用したいと思います。
「いいね!」 1
プラグインは現在、ニュースソースのカテゴリを使用することはサポートしていますが、タグはサポートしていません。
「いいね!」 2
タグは投稿の概念ではなく、トピックレベルのものであることを指摘しておきます。そのため、いずれにしてもご要望は困難です。
「いいね!」 2
まさにタイプしながらそう思っていました…
投稿ID以外に、これらの投稿を抽出するための投稿を特定する方法はありますか?
「いいね!」 1
これらの設定を有効にしています。トピックプレビュープラグインもデフォルトテーマで有効にしています。表示されるのは以下の通りです。
「いいね!」 1
