Backup notturno fallito
Hi!
We are using discourse_docker with Discourse v2.2.0.beta10 +6
Our nightly backup has failed a couple of times during the last month.
The log says:
[2019-02-17 03:31:42] Finalizing backup...
[2019-02-17 03:31:42] Creating archive: forum-2019-02-17-033115-v20190125153345.tar.gz
[2019-02-17 03:31:42] Making sure archive does not already exist...
[2019-02-17 03:31:42] Creating empty archive...
[2019-02-17 03:31:42] Archiving data dump...
[2019-02-17 03:31:43] Archiving uploads...
[2019-02-17 03:34:19] EXCEPTION: /var/www/discourse/lib/backup_restore/backuper.rb:237:in `block in create_archive': Failed to archive uploads.
[2019-02-17 03:34:19] /var/www/discourse/lib/discourse.rb:29:in `execute_command'
/usr/local/lib/ruby/2.5.0/fileutils.rb:122:in `chdir'
/usr/local/lib/ruby/2.5.0/fileutils.rb:122:in `cd'
/var/www/discourse/lib/backup_restore/backuper.rb:235:in `create_archive'
[2019-02-17 03:34:19] Deleting old backups...
[2019-02-17 03:34:19] Something went wrong while deleting old backups.
[2019-02-17 03:34:19] Cleaning stuff up...
[2019-02-17 03:34:19] Removing '.tar' leftovers...
[2019-02-17 03:34:19] Unpausing sidekiq...
[2019-02-17 03:34:19] Marking backup as finished...
[2019-02-17 03:34:19] Refreshing disk stats...
[2019-02-17 03:34:21] Notifying 'system' of the end of the backup...
Seems like it fails to archive (tar) the backups? But it doesn’t say why.
Regards,
Jonas
Upgrading should fix it. I recommend you do a rebuild on the console:
./launcher rebuild app
