Discourseのバックアップが失敗した場合のバックアップ方法
Hi guys, how can I backup Discourse when the backup has failed.
[2020-08-04 23:22:28] Marking backup as running...
[2020-08-04 23:22:28] Making sure '/var/www/discourse/tmp/backups/default/2020-08-04-232228' exists...
[2020-08-04 23:22:28] EXCEPTION: No space left on device - /var/www/discourse/tmp/backups/default/2020-08-04-232228
[2020-08-04 23:22:28] /usr/local/lib/ruby/2.0.0/fileutils.rb:245:in `mkdir'
/usr/local/lib/ruby/2.0.0/fileutils.rb:245:in `fu_mkdir'
/usr/local/lib/ruby/2.0.0/fileutils.rb:219:in `block (2 levels) in mkdir_p'
/usr/local/lib/ruby/2.0.0/fileutils.rb:217:in `reverse_each'
/usr/local/lib/ruby/2.0.0/fileutils.rb:217:in `block in mkdir_p'
/usr/local/lib/ruby/2.0.0/fileutils.rb:203:in `each'
/usr/local/lib/ruby/2.0.0/fileutils.rb:203:in `mkdir_p'
/var/www/discourse/lib/backup_restore/backuper.rb:326:in `ensure_directory_exists'
/var/www/discourse/lib/backup_restore/backuper.rb:27:in `run'
/var/www/discourse/lib/backup_restore/backup_restore.rb:161:in `block in start!'
/var/www/discourse/lib/backup_restore/backup_restore.rb:158:in `fork'
/var/www/discourse/lib/backup_restore/backup_restore.rb:158:in `start!'
/var/www/discourse/lib/backup_restore/backup_restore.rb:13:in `backup!'
/var/www/discourse/app/controllers/admin/backups_controller.rb:31:in `create'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/implicit_render.rb:4:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/abstract_controller/base.rb:198:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/rendering.rb:10:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:117:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:555:in `block (2 levels) in compile'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:505:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:92:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:778:in `_run_process_action_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:81:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/abstract_controller/callbacks.rb:19:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/rescue.rb:29:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/notifications.rb:164:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/notifications.rb:164:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/params_wrapper.rb:250:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/railties/controller_runtime.rb:18:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/abstract_controller/base.rb:137:in `process'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionview-4.2.5/lib/action_view/rendering.rb:30:in `process'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.7/lib/mini_profiler/profiling_methods.rb:106:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal.rb:196:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal.rb:237:in `block in action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/routing/route_set.rb:76:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/routing/route_set.rb:76:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/routing/route_set.rb:45:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/routing/mapper.rb:49:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/journey/router.rb:43:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/journey/router.rb:30:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/journey/router.rb:30:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/routing/route_set.rb:817:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:186:in `call!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:164:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/builder.rb:59:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/conditionalget.rb:38:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/head.rb:13:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:129:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/params_parser.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/flash.rb:260:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/session/abstract/id.rb:225:in `context'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/session/abstract/id.rb:220:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/cookies.rb:560:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/query_cache.rb:36:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/connection_adapters/abstract/connection_pool.rb:653:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:88:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:778:in `_run_call_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/callbacks.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/remote_ip.rb:78:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/logster-1.0.1/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5/lib/rails/rack/logger.rb:22:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:10:in `call_with_quiet_assets'
/var/www/discourse/config/initializers/100-silence_logger.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/request_id.rb:21:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/methodoverride.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/runtime.rb:18:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/sendfile.rb:113:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.7/lib/mini_profiler/profiler.rb:276:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/message_bus-2.0.0.beta.2/lib/message_bus/rack/middleware.rb:60:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:73:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5/lib/rails/engine.rb:518:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5/lib/rails/application.rb:165:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5/lib/rails/railtie.rb:194:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5/lib/rails/railtie.rb:194:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/urlmap.rb:66:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:580:in `process_client'
/var/www/discourse/lib/scheduler/defer.rb:85:in `process_client'
/var/www/discourse/lib/middleware/unicorn_oobgc.rb:95:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:674:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:529:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:140:in `start'
I have over 90GB of free space.
これは本当に古いインストールですか?
Discourse がボリュームをマウントしているディスクには、この空き容量がないようです。
@pauln さん、こんにちは。
前のトピックで、非常に古い Linode Debian 7.5 VPS を使用されていると仰っていましたが、
これは段階的に進めれば簡単に解決できる問題です。
まず、ファイルシステムのディスク使用量のレポートを確認できるよう、以下のコマンドの出力結果を投稿してください。
df
また、以下のコマンドでファイル使用量の概要も提供してください。
cd /var/discourse/shared
du -sh *
これは簡単に解決できる問題ですので、ご安心ください。
注:以前のトピックに基づき、新しい VPS への移行を準備中であると想定しています。
このインストールに関する @pauln さんの以前の投稿への参照:
df の出力のサマリーです
du -sh * の出力のサマリーです
はい、新しい VPS へ移行する予定ですが、移行前にまずバックアップを作成しようとしています。
はい、承知しています。あなたは正しい手順を踏んでおり、よくやっています。
別の戦略を試してみましょう。
アップロードファイルを含めずに正常にバックアップを作成することはできますか?
可能であれば、そのバックアップ (1) と、アップロードディレクトリを別々に tar したファイル (2) を組み合わせることで、ご希望の作業を完了させることができます。
したがって、まずはアップロードファイルを含めないバックアップ(下の中央のボタン)を試してください。バックアップウィンドウでそのオプションを選択し、結果を返信してください。
もし失敗した場合は、コマンドラインから手動でデータベースのバックアップを作成する方法を試します :slight_smile: 。これは比較的簡単で、確実に機能します(私たちはこれを頻繁に行っており、UX からの復元はほとんど行いません)。
参考:
注意:
@pauln さん、どのような方法を選択されるにせよ、新しい VPS で Discourse の別のインスタンスを正常にインストールし(復元およびテストまで含めて)、それが完了するまで、既存の Debian 7.5 および Discourse が動作している VPS を破棄しないでください。
それも失敗しましたね。次はコマンドラインで実行しましょうか?
はい、その通りです。
それで問題ないはずです。
その結果や、さらにサポートが必要かどうかお知らせください。以下の手順が必要です:
  1. PostgreSQL Discourse データベースの手動ダンプを実行する
  2. uploads フォルダの手動アーカイブを作成する
上記の参考資料には、手動アーカイブの作成方法について記載されています。
ただし、私が今すぐその手順をテストしたところ、コンテナ内から共有ディレクトリへの書き込みができませんでした。そのため、まず以下の手順を実行しました(インスタンス名が app であると仮定):
docker exec -it app bash
mkdir /shared/mybackups
chown postgres /shared/mybackups
その後、すべてのパスを /shared ではなく /shared/mybackups へ書き込むように変更しましたが、あなたはその問題に直面しないかもしれません。
今後の進捗をお待ちしています。
こんにちは、あなたの助けにとても感謝しています。うまくいきました。新しいVPSに移行し、今は問題なく動作しています :slight_smile:
素晴らしいニュース、そして素晴らしい仕事ですね、@pauln さん。
アップグレード成功おめでとうございます!
