Nessun accesso dopo l'installazione
I just completed install and wizard. After the next time I try to log in I get the following error
:frowning:
Access Denied
while trying to load /admin/dashboard-next.json
Something went wrong.
My guess is that you are not logged in properly.
It is intermittent. It looks like it may be related to log in timing out in some way. It usually occurs after a few min of inactivity on a screen.
@sam can you elaborate on that? I am also getting a “403 Forbidden” sometimes when I try to post topics.
Are you running any browser extensions that kill your cookies, are you behind cloudflare?
Hi there.
I am having the same issue.
Happened just after an update.
Any idea how to fix it ?
Thanks
