No bold formatting of text in parentheses
Problem: No bold formatting for text in parentheses, when there are leading or trailing characters around the parentheses.
Example text in which we want to highlight (5255):
1.0.15 Build 20200721 rel.40773(5255)
40773**(5255)** → NOK
40773(5255)
407735255
Now we add a single dot at the end of the first line.
Notice how 1st, 2nd + 3rd line change:
40773**(5255).
40773(5255)
40773
5255**
Playing around with other examples
No parentheses: All is OK.
parentheses → OK
parentheses → OK
aparentheses1 → OK
aparenthesesa → OK
aparentheses.1 → OK
aparentheses#1 → OK
aparentheses?1 → OK
With parentheses: Strange things happen.
parentheses → OK
(parentheses) → OK
**(parentheses)**1 → NOK
(parentheses).1 → OK
**(parentheses)**a → NOK
(parentheses).a → NOK
(parentheses)#1 → OK
(parentheses)?1 → OK
a**(parentheses)1 → NOK
a
a**(parentheses)**1 → NOK
Two times the same line, separated by blank line
paren**(thes)**es → NOK
Same as above, except no blank line separation
(paren)theses → NOK
paren
(theses)
→ NOK
If I recall correctly, this is a limitation of the Markdown spec.
This is the spec we follow. Try there – it doesn’t work either.
There are limitations to what parsers can do in a performant way, and I can’t say I’ve seen a Markdown parser work as you’re describing in any instance, though I could be wrong.
