קישורי Markdown אינם מפרשים כראוי סוגריים בקישורי URL
סיכום מבוסס בינה מלאכותית
The discussion is about Markdown links not interpreting parenthesis in URLs correctly. hellekin states that when a URL with unbalanced parentheses is used as a Markdown link, it does not work. Alteras suggests balancing the parentheses to fix the issue, citing the CommonMark Spec. Falco also mentions that escaping the unbalanced parentheses can solve the problem. However, hellekin notes that balancing or escaping parentheses is not a practical solution. Moin references another topic (ensure that links containing parentheses still render and work correctly) related to this issue.
Continuing the discussion from URLs in parenthesis do not turn into links:
Section 2.3 of RFC2396 states that:
Unreserved characters can be escaped without changing the semantics of the URI, but this should not be done unless the URI is being used in a context that does not allow the unescaped character to appear.
Parenthesis are such characters. When pasted into Discourse, URLs using those characters, e.g., in query strings for advanced search in certain contexts, are misinterpreted as part of the Markdown URL syntax and rendered unusable.
For example, this URL would retrieve a list of legally deposited books published by my association:
https://www.depotlegal.be/Depot/form.aspx?SC=KBRVITRINE1#/Search/(query:(AdvancedQuery:(queryGroups:!((queryClauses:!((index:KBR264b_idx,logical:0,operator:0,otherValue:!n,value:‘petites%20singularités’)
Although it works when pasted, as above, when used as a Markdown link, it does not work anymore:
[anchor](url) → [anchor](https://www.depotlegal.be/Depot/form.aspx?SC=KBRVITRINE1#/Search/(query:(AdvancedQuery:(queryGroups:!((queryClauses:!((index:KBR264b_idx,logical:0,operator:0,otherValue:!n,value:‘petites%20singularités’))
Moreover, when such an URL is received by email, the result is:
Recherche avancée - Depot)))),ForceSearch:!t,Grid:!n,Page:0,PageRange:3,QueryString:!n,ResultSize:-1,ScenarioCode:KBRVITRINE1,SearchContext:1))
where “Recherche avancée - Depot” is the correctly interpreted link title (which is clickable), and the rest is garbage – and absent from the clickable link. (Email is set to receive in HTML) Rebuilding HTML does not fix the link.
This looks more like an issue with the URL and commonmark. If you balance the opening and closing parentheses by adding )))))) to the end, the markdown link is properly parsed.
link
[link](https://www.depotlegal.be/Depot/form.aspx?SC=KBRVITRINE1#/Search/(query:(AdvancedQuery:(queryGroups:!((queryClauses:!((index:KBR264b_idx,logical:0,operator:0,otherValue:!n,value:'petites%20singularit%C3%A9s'))))))))
This matches the behavior in the CommonMark Spec, which the markdown-it engine follows (used by Discourse).
a nonempty sequence of characters that does not start with <, does not include ASCII control characters or space character, and includes parentheses only if (a) they are backslash-escaped or (b) they are part of a balanced pair of unescaped parentheses. (Implementations may impose limits on parentheses nesting to avoid performance issues, but at least three levels of nesting should be supported.)
This can be tested also in the markdown-it demo.
3 לייקים
The spec appears to be quite clear, the user may also escape the unbalanced parenthesis
[link](https://www.depotlegal.be/Depot/form.aspx?SC=KBRVITRINE1#/Search/\(query:\(AdvancedQuery:\(queryGroups:!\(\(queryClauses:!\(\(index:KBR264b_idx,logical:0,operator:0,otherValue:!n,value:'petites%20singularit%C3%A9s'\))
becomes
link
Since this is working as described in the spec I’m moving it to Contribute > Feature discussion.
4 לייקים
Unfortunately, balancing parenthesis or escaping them won’t happen most of the time :slight_smile:
I think there is another Contribute > Bug topic about this Ensure that links containing )) still render and work correctly
לייק 1
