Basically, this happened:
It says there is a new topic, but there are no new topics. What’s even more annoying is that there is no dismiss button. Just reporting this because it’s just SO ANNOYING.
Edit: did i seriously misspell that
Does refreshing the site clear the wrong count?
Try loading both /new and /unread in new tabs, it should clear the phantom topic.
@Moin @Firepup650 those worked, but I also found a solution.
Could you share what solved your issue?
If you go to the topics sections, then it will clear the topic/“phantom” topic.
Glad this works on our end
I think this has already been reported here too:
Let’s close this one off and keep the older one. ![]()
