No option appears to choose better answer
I understand that you want to get your site up and running as fast as possible. But if you are a newbee in this kind of stuff (like myself), you need to take your time and carefully read and follow instructions.
And although instructions are often written in a very step by step manner (thank you to all tutorial writers :+1:) I suggest you also try to understand (at a basic level) what you are actually doing in each step. That takes a bit longer but will safe you time and hassle in the long run, because you gradually get knowledgeable in what you’re doing.
Thanks for the suggestion, I will take more care when running something, but you need the solution plugin.
Can you please run
sudo nano /var/discourse/containers/app.yml
Find Line 98 and post a screenshot here. Be sure to blur out any sensitive info in the screenshot.
I was able to install, thanks for the help!
The plugins are active, but the solution icon still does not appear
You need to enable it in each category’s settings. Have another read through the plugin’s thread I linked earlier
This topic was automatically closed after 2587 days. New replies are no longer allowed.
