patronit
(Oliver)
October 20, 2025, 9:20am
1
Hi.
Since two or three weeks our instance of discourse does not update any notifications as read (new topic/message/chat).
And I guess, no logged-in user gets notifications of new messages/topic/chat while logged in.
The installed version is: 3.6.0.beta2-latest (1354173224) on ubuntu server 22.04.5.
It seems not to be a browser problem. The problem occurs on firefox and chrome.
Any hot tip or hint?
Thank you for your help.
Any errors in /logs? Does this also happen in safe mode ? Thanks.
patronit
(Oliver)
October 20, 2025, 9:35am
3
Security - Protocols and Screenings - Error-Logs is no error.
In safe mode I get a new message only if I reload the page.
patronit
(Oliver)
October 20, 2025, 9:36am
4
… and if I read the new message the notification icon for unread messages does not disapear.
patronit
(Oliver)
October 20, 2025, 9:45am
5
Ok. There is a warning with the date of the last update (October 18th):
Message
Sidekiq heartbeat test failed for 7409, restarting
Backtrace
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-8.0.3/lib/active_support/broadcast_logger.rb:218:in block in dispatch' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-8.0.3/lib/active_support/broadcast_logger.rb:217:in map’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-8.0.3/lib/active_support/broadcast_logger.rb:217:in dispatch' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-8.0.3/lib/active_support/broadcast_logger.rb:129:in warn’
/var/www/discourse/lib/demon/sidekiq.rb:39:in block in heartbeat_check' /var/www/discourse/lib/demon/sidekiq.rb:31:in each’
/var/www/discourse/lib/demon/sidekiq.rb:31:in heartbeat_check' config/unicorn.conf.rb:131:in block (2 levels) in reload’
One error October 3rd:
Message (4 copies reported)
Job exception: Unsupported command argument type: TrueClass
Backtrace
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/redis-client-0.25.3/lib/redis_client/command_builder.rb:37:in block in generate' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/redis-client-0.25.3/lib/redis_client/command_builder.rb:28:in map!’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/redis-client-0.25.3/lib/redis_client/command_builder.rb:28:in generate' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/redis-client-0.25.3/lib/redis_client.rb:313:in call_v’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/redis-5.4.0/lib/redis/client.rb:90:in call_v' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-4.0.1/lib/mini_profiler/profiling_methods.rb:90:in block in profile_method’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/redis-5.4.0/lib/redis.rb:152:in block in send_command' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/redis-5.4.0/lib/redis.rb:151:in synchronize’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/redis-5.4.0/lib/redis.rb:151:in send_command' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/redis-5.4.0/lib/redis/commands/hashes.rb:51:in hmset’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/redis-5.4.0/lib/redis/commands/hashes.rb:66:in mapped_hmset' /var/www/discourse/lib/discourse_redis.rb:144:in public_send’
/var/www/discourse/lib/discourse_redis.rb:144:in block (3 levels) in <class:DiscourseRedis>' /var/www/discourse/lib/discourse_redis.rb:29:in ignore_readonly’
/var/www/discourse/lib/discourse_redis.rb:144:in block (2 levels) in <class:DiscourseRedis>' /var/www/discourse/lib/discourse_updates.rb:116:in block in missing_versions=’
/var/www/discourse/lib/discourse_updates.rb:114:in each' /var/www/discourse/lib/discourse_updates.rb:114:in missing_versions=’
/var/www/discourse/app/jobs/scheduled/call_discourse_hub.rb:19:in execute' /var/www/discourse/app/jobs/base.rb:318:in block (2 levels) in perform’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-7.0.0/lib/rails_multisite/connection_management/null_instance.rb:49:in with_connection' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-7.0.0/lib/rails_multisite/connection_management.rb:17:in with_connection’
/var/www/discourse/app/jobs/base.rb:305:in block in perform' /var/www/discourse/app/jobs/base.rb:301:in each’
/var/www/discourse/app/jobs/base.rb:301:in perform' /var/www/discourse/app/jobs/base.rb:381:in perform’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_scheduler-0.18.0/lib/mini_scheduler/manager.rb:137:in process_queue' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_scheduler-0.18.0/lib/mini_scheduler/manager.rb:77:in worker_loop’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_scheduler-0.18.0/lib/mini_scheduler/manager.rb:63:in `block (2 levels) in ensure_worker_threads’
And one error in September 16th:
Message (5 copies reported)
Job exception: execution expired
Backtrace
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-smtp-0.5.1/lib/net/smtp.rb:663:in initialize' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-smtp-0.5.1/lib/net/smtp.rb:663:in open’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-smtp-0.5.1/lib/net/smtp.rb:663:in tcp_socket' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-smtp-0.5.1/lib/net/smtp.rb:672:in block in do_start’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/timeout-0.4.3/lib/timeout.rb:185:in block in timeout' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/timeout-0.4.3/lib/timeout.rb:192:in timeout’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-smtp-0.5.1/lib/net/smtp.rb:671:in do_start' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-smtp-0.5.1/lib/net/smtp.rb:642:in start’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mail-2.8.1/lib/mail/network/delivery_methods/smtp.rb:109:in start_smtp_session' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mail-2.8.1/lib/mail/network/delivery_methods/smtp.rb:100:in deliver!’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mail-2.8.1/lib/mail/message.rb:269:in deliver!' /usr/local/lib/ruby/3.3.0/delegate.rb:87:in method_missing’
/var/www/discourse/lib/email/sender.rb:296:in send' /var/www/discourse/app/jobs/regular/user_email.rb:79:in send_user_email’
/var/www/discourse/app/jobs/regular/user_email.rb:39:in execute' /var/www/discourse/app/jobs/base.rb:318:in block (2 levels) in perform’
/var/www/discourse/app/jobs/base.rb:301:in perform' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:220:in execute_job’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:185:in block (4 levels) in process' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:180:in traverse’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:183:in block in traverse' /var/www/discourse/lib/sidekiq/discourse_event.rb:6:in call’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:182:in traverse' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:183:in block in traverse’
/var/www/discourse/lib/sidekiq/pausable.rb:131:in call' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:182:in traverse’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:183:in block in traverse' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job/interrupt_handler.rb:9:in call’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/metrics/tracking.rb:26:in track' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/metrics/tracking.rb:134:in call’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:182:in traverse' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:173:in invoke’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:184:in block (3 levels) in process' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:145:in block (6 levels) in dispatch’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_retry.rb:118:in local' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:144:in block (5 levels) in dispatch’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/config.rb:39:in block in <class:Config>' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:139:in block (4 levels) in dispatch’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:281:in stats' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:134:in block (3 levels) in dispatch’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_logger.rb:15:in call' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:133:in block (2 levels) in dispatch’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_retry.rb:85:in global' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:132:in block in dispatch’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_logger.rb:40:in prepare' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:131:in dispatch’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:183:in block (2 levels) in process' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:182:in handle_interrupt’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:182:in block in process' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:181:in handle_interrupt’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:181:in process' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:86:in process_one’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:76:in run' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/component.rb:10:in watchdog’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/component.rb:19:in `block in safe_thread’
sam
(Sam Saffron)
October 22, 2025, 6:06am
6
Whatever is happening here is unlikely to be those issues.
Do you have any custom plugins installed? Can you try safe mode ?
@sam They tried safe mode , but it doesn’t to be working well.
@patronit were you able to figure this out?
patronit
(Oliver)
October 31, 2025, 10:14am
9
We did not activate custom plugins, even not the ones, which are now bundled.
As theme is Minima selectable.
patronit
(Oliver)
October 31, 2025, 10:25am
10
Today October 31st we use 3.6.0.beta2-latest (47559c86f5 ) in safe-mode:
When I write a message (Nachricht) the new message is shown in the menue “Benachrichtigungen und Konto” but without a “new” flag und number.
In normal mode:
Only F5 helps.
Tomorrow ist update-day…
