J’ai besoin d’un peu de guidance pour migrer de NodeBB vers Discourse. J’ai vu ce fil de discussion et j’ai remarqué que @eatcodetravel a créé le script. Je n’arrive pas à comprendre comment ces scripts sont exécutés. Dois-je également installer Redis sur le serveur où Discourse est hébergé pour l’importation ?
You need redis to run discourse. The nodebb importer is only available if you use redis as your nodebb database. Here is how I would do the migration.
Setup a discourse environment (it can be your machine or an instance in the cloud)
Change the nodebb importer configuration (take a look at the code, there’s comments on what you need to replace)
Run the importer with bundle exec ruby script/import_scripts/nodebb/nodebb.rb from the discourse folder
(Optional) make a backup of discourse and restore it where you need it
The importer will connect to your nodebb redis database and copy everything over discourse, the time it takes is related to the amount of data you have. Also, you need to wait for discourse to finish processing jobs before you do the backup, go to /sidekiq route as an admin and you will see the pending/completed jobs
Je fais fonctionner Discourse via Digital Ocean et Docker. J’ai édité script/import_scripts/nodebb/nodebb.rb à l’intérieur du conteneur et modifié ATTACHMENT_DIR pour inclure le répertoire où se trouve NodeBB. J’ai également placé le répertoire NodeBB à l’intérieur du conteneur.
I neglected to write down the actual paths to files, I just had those notes from when I did it.
Are you using a dev environment outside of the Docker image? it might make it easier ensure redis is stopped when you replace the dump.rdb file.
Edit: I wrote this before finishing coffee. So the reason I suggest that you need to have redis stopped is that I don’t think it will read from the dump file until after it has been stopped (redis stores the database in memory and periodically writes to the dump.rdb file)
J’ai essayé d’arrêter Redis, mais il semble continuer à s’exécuter, quoi que je fasse. J’ai tué le processus une douzaine de fois, mais il fonctionne toujours.
