NoScript tag being rejected in Body Component
Good morning everyone, I am running into a issue when I try to add this noscript tag that contains an iframe to the the Body component within Discourse. Any idea what may be the hold up here? Thanks in advance!
That warning is added by the Ace Editor. If you save the theme I think you’ll see that the noscript tag gets added to your HTML in spite of the warning.
There is a similar issue with a warning being displayed for the html tag on the default Discourse email template. Possibly there is an Ace Editor configuration option that we could use to suppress these warnings.
I was able to select save and the code persists. I appreciate the help, I was just concerned it was going to bring a problem forward.
