NOT FOUND and Partition table entries are not in disk order
What is happening ?
Why am I getting NOT FOUND and Partition tables not in disk order ? Just did the advised install on digital ocean with zeptomail though.
==================== DOCKER INFO ====================
DOCKER VERSION: Docker version 24.0.6, build ed223bc
DOCKER PROCESSES (docker ps -a)
CONTAINER ID   IMAGE                 COMMAND        CREATED              STATUS              PORTS        NAMES
1f2a5b6e252e   local_discourse/app   "/sbin/boot"   About a minute ago   Up About a minute   0.0.0.0:80->80/tcp, :::80->80/tcp, 0.0.0.0:443->443/tcp, :::443->443/tcp   app
Discourse container app is running
==================== PLUGINS ====================
No non-official plugins detected.
See https://github.com/discourse/discourse/blob/main/lib/plugin/metadata.rb for the official list.
*Discourse version at forum.xxx.dk: NOT FOUND*
*Discourse version at localhost: NOT FOUND*
==================== MEMORY INFORMATION ====================
RAM (MB): 999
               total        used        free      shared  buff/cache   available
Mem:             952         876          68          23         187          76
Swap:           2047         343        1704
==================== DISK SPACE CHECK ====================
---------- OS Disk Space ----------
/dev/vda1        25G  9.2G   15G  39% /
==================== DISK INFORMATION ====================
Disk /dev/loop0: 73.9 MiB, 77492224 bytes, 151352 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 175.48 MiB, 184004608 bytes, 359384 sectors
Disk /dev/loop2: 40.84 MiB, 42827776 bytes, 83648 sectors
Disk /dev/vda: 25 GiB, 26843545600 bytes, 52428800 sectors
Disklabel type: gpt
Disk identifier: 293A0243-F40E-41AD-96A3-FFA36BBF90EA
Device      Start      End  Sectors  Size Type
/dev/vda1  227328 52428766 52201439 24.9G Linux filesystem
/dev/vda14   2048    10239     8192    4M BIOS boot
/dev/vda15  10240   227327   217088  106M EFI System
Partition table entries are not in disk order.
Disk /dev/vdb: 474 KiB, 485376 bytes, 948 sectors
==================== END DISK INFORMATION ====================
==================== MAIL TEST ====================
For a robust test, get an address from http://www.mail-tester.com/
Or just send a test message to yourself.
Email address for mail test? ('n' to skip) [xxx]: n
Mail test skipped.
Replacing: SMTP_PASSWORD
Replacing: LETSENCRYPT_ACCOUNT_EMAIL
Replacing: DEVELOPER_EMAILS
Replacing: DISCOURSE_DB_PASSWORD
Replacing: Sending mail to
==================== DONE! ====================
Not found means discourse isn’t running. Or hasn’t fully started.
The partition table thing doesn’t matter. You don’t care about that.
Is discourse working now?
