Not possible to edit wiki articles with system user
I wanted to make changes to a wiki with the system user, but I can only change headings, not content. Here I get an error message in the console and in the browser “Error 422”. I could already rule out that it is due to the new content, as I can save it with a normal user. It is also not the article itself, others cannot be saved either.
What works, however, is to create a new article with the system user, and it is then possible to edit it afterwards.
Discourse 3.2.0.beta5-dev
error in console:
ajax-error.js:35 SyntaxError: Unexpected token '<', "<!DOCTYPE "... is not valid JSON
    at Function.parse [as parseJSON] (<anonymous>)
    at l (ajax-error.js:31:20)
    at c (ajax-error.js:74:10)
    at ajax-error.js:83:11
    at _ (rsvp.js:434:1)
    at y (rsvp.js:420:1)
    at m (rsvp.js:369:1)
    at invoke (backburner.js.js:282:1)
    at h.flush (backburner.js.js:197:1)
    at p.flush (backburner.js.js:358:1)
    at B._end (backburner.js.js:798:1)
    at B.end (backburner.js.js:589:1)
    at B._run (backburner.js.js:842:1)
    at B.run (backburner.js.js:624:1)
    at e.run (index.js:75:1)
    at t.error (ajax.js:148:7)
    at l (jquery.js:3223:31)
    at Object.fireWith [as rejectWith] (jquery.js:3353:7)
    at T (jquery.js:9629:14)
    at XMLHttpRequest.<anonymous> (jquery.js:9888:9)
l @ ajax-error.js:35
c @ ajax-error.js:74
(anonymous) @ ajax-error.js:83
_ @ rsvp.js:434
y @ rsvp.js:420
m @ rsvp.js:369
invoke @ backburner.js.js:282
flush @ backburner.js.js:197
flush @ backburner.js.js:358
_end @ backburner.js.js:798
end @ backburner.js.js:589
_run @ backburner.js.js:842
run @ backburner.js.js:624
e.run @ index.js:75
t.error @ ajax.js:148
l @ jquery.js:3223
fireWith @ jquery.js:3353
T @ jquery.js:9629
(anonymous) @ jquery.js:9888
load (async)
send @ jquery.js:9907
ajax @ jquery.js:9521
f @ ajax.js:173
(anonymous) @ rsvp.js:457
k @ rsvp.js:913
k @ ajax.js:192
update @ rest.js:119
update @ store.js:197
update @ rest.js:30
save @ rest.js:89
(anonymous) @ composer.js:1011
_ @ rsvp.js:434
y @ rsvp.js:420
e.run @ index.js:75
t.success @ ajax.js:118
l @ jquery.js:3223
T @ jquery.js:9627
load (async)
f @ ajax.js:173
k @ rsvp.js:913
k @ ajax.js:192
update @ topic.js:722
(anonymous) @ composer.js:983
_ @ rsvp.js:434
(anonymous) @ rsvp.js:489
B._boundAutorunEnd @ backburner.js.js:523
Promise.then (async)
n @ backburner.js.js:26
flush @ index.js:40
_scheduleAutorun @ backburner.js.js:964
_ensureInstance @ backburner.js.js:955
ensureInstance @ backburner.js.js:767
scheduleRevalidate @ index.js:3337
dirtyTag @ validator.js:368
T @ validator.js:440
M @ index.js:485
D @ index.js:521
Ae @ index.js:1796
Ce @ index.js:1772
set @ observable.js:23
save @ composer.js:1022
saveAction @ composer.js:822
_triggerAction @ d-button.js:115
click @ d-button.js:87
Ah, this could be another one where the new group-allowed settings aren’t playing nice with the system user. I think there has been a temporary fix put in place while a firmer solution is being worked on. Could you update your site from your /upgrade page and see if you still get the same issues?
It works for me. Thank you.
