L'icona di notifica non mostra le risposte ai topic
Is there any reason why notifications would not be sent?
I have tested by replying to topics between 2 users, however no notification alerts are sent.
Only shows topic update alert/highlight in front page list.
However, nothing shows on dropdown user menu:
Notifications are sent according to the selected tracking level for the user and topic:
If you repeat your tests with notification levels set to “watching”, does it notify the users as you are expecting?
Completely neglected to think of this, thanks :wink:
Also note that there is a very big conceptual difference between a reply to a topic (pressing reply button at the bottom or right side of the topic) and a reply to a specific post (quoting a post, pressing reply button on a post) or a specific person (a @username mention).
