Onebox kan geen voorbeeld tonen voor url met og metadatagegevens
Hi,
I’ve managed setup a discourse instance with discourse_docker, with version 2.7.0.beta4.
I’m facing a curious problem that with the same url it did generated onebox preview, however it fails several days later.
the url in problem is Dapr可视化指南-InfoQ
The error prints as below.
20210309141516
But I can find “og:description” and “og:image” in this url meta tags.
I’m not familiar with discourse code, any help will be appreciated, thanks!
finally I found that is an issue of my environment, I use an SNAT proxy and the some 1 outer IP of the proxy IP pool was blocked by the service provider.
