I did some further testing, none of them solve this bug.
Testing 1 . Restore the backup* which before the bug occur. Reboot system then got a 502 error
PS: VPS disk image backup on 4/27, not discourse backup zip file
The new backup file can restore and reboot without problem, only old backup failed. It’s wierd. Theoretically the old backup should work fine as the other backup.
Testing 2 . Clone the VPS disk image backup to a new VPS, followed the steps below to setup a new domain. The new site works fine, but this bug still exist. It should be due to rebuilt will load new discourse image which is the same.
This guide is for self-hosted Discourse instances that were installed using our installation guide on GitHub . If you are hosted by Discourse , please see Configure your domain name for hosted Discourse for specific instructions.
You may eventually want to change the domain name of your Discourse instance, from say
=BEFORE= → =AFTER=
Let’s get started.
Set the TTL for your DNS low, and in advance
You need to let everyone know that the domain is about to change, so change the TTL f…
Testing 3 . Follow the steps of web page below to see why 403.
Just tried a couple things:
From the DO box itself I can curl this URL fine:
http://www.amazon.com/The-Advantage-Organizational-Everything-Business/dp/1491510803
If I curl from within the docker container, though, I get a 503:
* Connection #0 to host www.google.com left intact
root@host:/# curl http://www.amazon.com/The-Advantage-Organizational-Everything-Business/dp/1491510803 -v -o deleteme
* Hostname was NOT found in DNS cache
% Total % Received % Xferd Average Speed Time …
The image here show the difference of onebox between meta(above) and my site(below).
Testing urls for udemy and amazon. It seems one in 403 and one in 503.
< HTTP/2 403
< date: Fri, 07 May 2021 10:18:28 GMT
< content-type: text/plain; charset=UTF-8
< content-length: 16
< x-frame-options: SAMEORIGIN
< cache-control: private, max-age=0, no-store, no-cache, must-revalidate, post-check=0, pre-check=0
< expires: Thu, 01 Jan 1970 00:00:01 GMT
< set-cookie: __cfduid=dbbbf721820c12aac03e8116c362147d51620382708; expires=Sun, 06-Jun-21 10:18:28 GMT; path=/; domain=.udemy.com; HttpOnly; SameSite=Lax
< cf-request-id: 09e7ef0b3c00000b939211d000000001
< expect-ct: max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"
< set-cookie: __cf_bm=f83cbaa075085ed2ae624e9bcfa5badf394f7ddd-1620382708-1800-Af1qbDD41LzYLWJX0XR39JAeFnjBdEmvhZO/0YloMwnBR8urb60m7+bcte18X+L59RfHKhzWeGPELN02cuiV9RA=; path=/; expires=Fri, 07-May-21 10:48:28 GMT; domain=.udemy.com; HttpOnly; Secure; SameSite=None
< x-content-type-options: nosniff
< server: cloudflare
< cf-ray: 64b9b4585d9b0b93-NRT
{ [16 bytes data]
100 16 100 16 0 0 290 0 --:--:-- --:--:-- --:--:-- 296
* Connection #0 to host www.udemy.com left intact
< HTTP/2 503
< server: Server
< date: Fri, 07 May 2021 10:25:04 GMT
< content-type: text/html
< strict-transport-security: max-age=47474747; includeSubDomains; preload
< x-amz-rid: P43ZS4CBG7V92Z7W4VSC
< vary: Content-Type,Accept-Encoding,X-Amzn-CDN-Cache,X-Amzn-AX-Treatment,User-Agent
< last-modified: Wed, 30 Sep 2020 23:54:00 GMT
< etag: "a6f-5b0909d09d600"
< accept-ranges: bytes
< content-length: 2671
{ [1139 bytes data]
100 2671 100 2671 0 0 11871 0 --:--:-- --:--:-- --:--:-- 11871
* Connection #0 to host www.amazon.com left intact
